DS1302 troubles
Fabian
DS1302 troubles
PostPosted: Mon Apr 12, 2004 8:09 am     Reply with quote
I get strange reading when trying to get my time values from DS1302. i've used the example schem as supplied with the DS1302 datasheet.
from ds1302.c:
#define RTC_SCLK Pin_A2
#define RTC_IO   Pin_A3
#define RTC_RST  Pin_A4
the example that's provided with CCS uses more pins than i, ... what gives?
from ex_rtcclk.c
#define RTC_SCLK  PIN_B1
#define RTC_RST   PIN_B2
#define RTC_CE    PIN_D0
#define RTC_IO    PIN_D1
#define RTC_CLK   PIN_D2
#define RTC_DATA  PIN_D3
#include <ds1302.c>
my approach:
i get the need values for time from rs232 input and write them with the supplied function from the ds1302 driver. (tried with BCD formating too)
when i read the clock it returns unreasanable values...
BYTE day=5,mth=6,year=7,dow=1,hour=8,min=1,sec=23;
//macro from bcd 2 dec
#define fromBCD(x) ((x & 0xf)+conv[(x>>4)])
//from dec 2 bcd
byte get_bcd() {
  char first,second;
  do {
    first=getc();
  } while ((first<'0') || (first>'9'));
  putc(first);
  first-='0';
  do {
    second=getc();
  } while ((second<'0') || (second>'9'));
  putc(second);
  return((first<<4)|(second-'0'));
// set clock
void set_clock(){
   byte day,mth,year,dow,hour,min;
   puts("Year 20: ");
   year=get_bcd();
   puts("Month: ");
   mth=get_bcd();
   puts("Day: ");
   day=get_bcd();
   puts("Weekday 1-7: ");
   dow=get_bcd();
   puts("Hour: ");
   hour=get_bcd();
   puts("Min: ");
   min=get_bcd();
   printf("\n\r %2d,%2d,%2d,  %2d um %2d:%2d\n",fromBCD(day),fromBCD(mth),fromBCD(year),fromBCD(dow),fromBCD(hour),fromBCD(min));
   rtc_set_datetime(day,mth,year,dow,hour,min);
   printf("\n\r Uhr gestellt");
void get_clock()
   printf("\n\r...%2d:%2d:%2d...\n",fromBCD(hour),fromBCD(min),fromBCD(sec));
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   rtc_init();
 printf("\n\r...start...\n");
      set_clock();
  do {
      get_clock();
      delay_ms(3000);
      get_clock();
     } while (TRUE);
PostPosted: Mon Apr 12, 2004 10:15 am     Reply with quote
Pin A4 will require a pull-up resistor on it. Do you have one ?
PostPosted: Mon Apr 12, 2004 10:54 am     Reply with quote
nope, which value should the pull up resistor have?
PostPosted: Mon Apr 12, 2004 12:00 pm     Reply with quote
I don't know what your PIC crystal frequency is --
it determines how quickly the clock line will toggle.
At higher ds1302 clock speeds, you need a faster
rise time on the clock edges. Just to be safe,
I would suggest using a 1K pull-up on pin A4.
PostPosted: Mon Apr 12, 2004 12:04 pm     Reply with quote
I'm using maxim's ds1302 but ist does not work correctly.
My problem is that I am able to set the time when it is running it only echos nonsense
code:
#include <16F877.h>
#include <DS1302.C>
BYTE day=1,mth=2,year=3,dow=4,hour=5,min=6,sec=7;
//bcd def
const unsigned int conv[16] = {
0,10,20,30,40,50,60,70,80,90,90,90,90,90,90,90 };
unsigned int toBCD(unsigned int val)
int ctr;
for (ctr=0;ctr<10;ctr++)
if (val == conv[ctr])
return(ctr<<4);
else if (val < conv[ctr]) break;
--ctr;
return((val-conv[ctr])+(ctr<<4));
} // end bcd def
byte get_bcd() {
  char first,second;
  do {
    first=getc();
  putc(first);
  first-='0';
  do {
    second=getc();
  putc(second);
void set_clock()
   puts("Year 20: ");
   year=get_bcd();
   puts("Month: ");
   mth=get_bcd();
   puts("Day: ");
   day=get_bcd();
   dow=get_bcd();
   puts("Hour: ");
   hour=get_bcd();
   puts("Min: ");
   min=get_bcd();
   puts("sec");
   sec=get_bcd();
   printf("\n\r clock setup");
void get_clock()
   rtc_get_time(hour,min,sec);
   printf("\n\r...%2d:%2d:%2d...\n",fromBCD(hour),fromBCD (min),fromBCD(sec));
   setup_adc(ADC_OFF);
   rtc_init();
      set_clock();
  do {
      get_clock();
      get_clock();
     } while (TRUE);
} //end main
Hyperterminal:
start
Year 20:
 04
Month:
 04
Day:
 13
Weekday 1-7:
 03
Hour:
 12
Min:
 00
sec
0 0
 13, 4, 4,   3 um 12: 0
... 0: 0: 0...
... 0: 0: 0...
ferdinand
PostPosted: Mon Apr 12, 2004 12:05 pm     Reply with quote
code:
#include <16F877.h>
#include <DS1302.C>
//bcd def
int ctr;
return(ctr<<4);
--ctr;
} // end bcd def
byte get_bcd() {
  char first,second;
  do {
    first=getc();
  putc(first);
  first-='0';
  do {
    second=getc();
  putc(second);
void set_clock()
   puts("Year 20: ");
   year=get_bcd();
   puts("Month: ");
   mth=get_bcd();
   puts("Day: ");
   day=get_bcd();
   dow=get_bcd();
   puts("Hour: ");
   hour=get_bcd();
   puts("Min: ");
   min=get_bcd();
   puts("sec");
   sec=get_bcd();
void get_clock()
   setup_adc(ADC_OFF);
   rtc_init();
      set_clock();
  do {
      get_clock();
      get_clock();
     } while (TRUE);
} //end main
Hyperterminal:
start
Year 20:
 04
Month:
 04
Day:
 13
Weekday 1-7:
 03
Hour:
 12
Min:
 00
sec
0 0
... 0: 0: 0...
... 0: 0: 0...
Fabian
PostPosted: Mon Apr 12, 2004 1:17 pm     Reply with quote
20Mhz crystal frequ.
PostPosted: Mon Apr 12, 2004 1:21 pm     Reply with quote
Does Fabian = Ferdinand ?
Did the pull-up resistor fix your problem,
or do you still have a problem ?
Fabian
PostPosted: Tue Apr 13, 2004 8:51 am     Reply with quote
jes we're working togehter on thist proŽject.
The problem is still existing.
We are going to have a look at the hardware with an oscilloscope towmorrow.
I'll post again if I can't solve it or do you have any further suggestions.
Thanks Fabian
rwyoung
PostPosted: Tue Apr 13, 2004 7:53 pm     Reply with quote
I have code that works with a DS1307 which is not exactly the same part as the DS1302. I can cut and paste my routines if you think that might help you. The code is working on a PIC16F76 and there is also an i2c EEPROM on the bus in addition to the DS1307.
Rob Young
Fabian
PostPosted: Tue Apr 13, 2004 10:03 pm     Reply with quote
yes i think that might help me alot.
pleas post it or give me a link to download this file
thanks
fabian
