pointer to array of structures
Ed Arnold
PostPosted: Sat Apr 10, 2004 9:25 pm     Reply with quote
I have two PICs communicating thru i2c. I want to send an entire structure to the slave PIC. So I need to use a pointer, right. Only, this is an array of stuctures. I have never done this before and can't seem to find any examples anywhere. Any input or examples would be recieved with much thanks.
static struct
  int UID;
  int time[3];
  int VAL_A;
  int VAL_B;
  int KEY_CODE;
  int DOLLARS;
  int CENTS;
}TRANS_QUE[16], *p_tque;
Ed Arnold
Neutone
PostPosted: Sun Apr 11, 2004 10:47 am     Reply with quote
If you set your pointer to the first byte of the structure array as a starting point you can develop it from there. Once you have that done you can increment the pointer by the structure size times the structure index you want to send. I seem to remember someone posting about using a sizeof function to determine the size of a structure in relation to this. Another artical that may help is this one linked.
http://www.embedded.com/showArticle.jhtml?articleID=18312031
Re: pointer to array of structures
PostPosted: Mon Apr 12, 2004 7:40 am     Reply with quote
static struct
  int UID;
  int time[3];
  int VAL_A;
  int VAL_B;
  int KEY_CODE;
  int DOLLARS;
  int CENTS;
Ed Arnold
If you do something like:
static struct mystruct {
  int UID;
  int time[3];
  int VAL_A;
  int VAL_B;
  int KEY_CODE;
  int DOLLARS;
  int CENTS;
int8 counter;
char *ptr;
ptr=(char *)TRANS_QUE;
for (counter=0;counter<sizeof(mystruct*16);counter++) {
    send_byte(*ptr++);
It should send the entire structure array using the routine 'send_byte' (suitable definition needed for this...).
