Interrupts
Michaelc
Interrupts
PostPosted: Fri Apr 02, 2004 8:09 am     Reply with quote
Hey
Can anyone tell my an interupt occurs when the pic is starting up?
The code is below:
#include<inttest.h>
#include<des_lcd.c>
#include<dipkey.c>
static int j;
////////Interrupt Service routine for change on port b////////////
#int_rb
rb_isr ( )
static int ran = 0;
static int portstatus;
portstatus = port_b;
j++;
printf("isr");
delay_ms(3000);
//////////////////////Declare Local Variables //////////////////////
static byte status;
int low_detected = 0;
//////////////////////Disable interrupts//////////////////////////////
disable_interrupts(GLOBAL);
disable_interrupts(INT_RB);
//////////////////////Initialise lcd//////////////////////////////////
lcd_init();
set_tris_b(0xf0);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
///////////////////////Setup Watchdog Counters////////////////////////
///////////////////////Reset = every 2.3secs /////////////////////////
setup_counters(RTCC_INTERNAL,WDT_2304MS);
///////////////////////////Setup Timers////////////////////////////////
setup_timer_1(T1_DISABLED);
//////////Setup interrupt on Port B change ////////////////////////////
status = port_b; //read the status before enabling the interrupt
enable_interrupts(INT_RB);
/////////////////////////Enable interrupts ////////////////////////////
enable_interrupts(global);
printf("reset");
i++;
restart_wdt();
//restart_wdt();
The interrupt ocurs on change on port b, but as can be seen i have the interrupts disabled. The program never reaches the printf("reset"); line!
Why is this?
PostPosted: Fri Apr 02, 2004 12:02 pm     Reply with quote
Where is your declaration for port_b ?
It should look like this, if you are using a 16F series PIC:
#byte port_b = 6
Neutone
PostPosted: Fri Apr 02, 2004 12:38 pm     Reply with quote
It's just a guess but I would try clearing the interupt flag between these two lines.
