watchdog reset
Michaelc
watchdog reset
PostPosted: Thu Apr 01, 2004 2:08 pm     Reply with quote
Iam trying to reset the pic using the watchdog timer??
What are the main things to be aware of when implementing this?
PostPosted: Thu Apr 01, 2004 4:14 pm     Reply with quote
Have a look at the links on this thread
http://www.ccsinfo.com/forum/viewtopic.php?p=7697#7697
valemike
Re: watchdog reset
PostPosted: Thu Apr 01, 2004 10:04 pm     Reply with quote
I've reset other micros (e.g. a powerpc and 680x0) by letting the watchdog timer time out, so I don't think it would be much different with the PIC.
void graceful_reset(void)
     save_stuff_if_you_have_to_in_eeprom();
     disable_interrupts();
I don't think there is anything else you should worry about.
valemike
Re: watchdog reset
Michaelc
watchdog reset and configuration bits (fuses)
PostPosted: Fri Apr 02, 2004 5:58 am     Reply with quote
Iam using a bootloader, and when i program the chip with the bootloader and turnoff the watchdog timer config bit the program including the bootloader work perfect, however if i turn on the watchdog bit and program the chip again from mplab using promate 2, with the bootloader program, the chip wont download? whats wrong here, and what way should the other configuration bits be set?
