int not 2 byte not volume +32767-3276
pic877
PostPosted: Thu Apr 01, 2004 6:52 am     Reply with quote
Confused
i write program read value from atd an0-an5 of 16f877 by code this
int x;
x=readadc();
x cann't show value 1024 if value from readadc(); more 127 x is = -128
help me i can't understand int not 2 byte?
pic877
again
PostPosted: Thu Apr 01, 2004 6:58 am     Reply with quote
and i printf to rs232 by code
printf("%d",x);
it show -128 ---> 127 only
but i change code is
long x;
x=readatd();
printf("%ld",x);
it work! i think ccs is not ansi c langguage it new c style !!!! Laughing
SteveS
PostPosted: Thu Apr 01, 2004 7:27 am     Reply with quote
ANSI C does not set the actual physical size of various data types (I think), so, in this case CCS is perfectly legal in saying an int is 8 bits. I have found (or actually learned from others on this list) that you will save yourself many headaches by using int8, int16 etc. It's a good reminder of the actual size of the variable you are creating, esp when you switch between embedded PIC and Windows programming as I do.
- SteveS
