Help with SD Card and PIC24
mrtele
PostPosted: Fri Jun 26, 2026 7:47 am     Reply with quote
Hello everyone,
I've been trying without much success to communicate with an sd card on a new project. I'm using a PIC24FJ512GB606, connected to the SD Card with the standard pinout for SPI communication.
Looking through the forum, I saw the pinned post "mmcsd.c and fat.c modified and fully functional", though unfortunately I was not able to use it as of yet, as my code is still using the setup_spi() and spi_read/write functions rather than the #use spi and spi_xfer option.
I've had some partial success with the driver from this page (https://simple-circuit.com/ccs-c-fat-library-for-mmc-sd-cards/), after modifying it, mostly to make sure all the variables are explicitly unsigned. I've made a few more changes to the init routine, according to the init sequences I've found online:
MMCSD_err mmcsd_init()
   uint8_t  i, r1, r3[4];
   g_CRC_enabled = TRUE;
   g_mmcsdBufferAddress = 0;
   output_drive(MMCSD_PIN_SELECT);
   to_spi_m0v();
   mmcsd_deselect();
   delay_ms(250);
    for(i = 0; i < 10; i++)                        // Send 80 cycles
      MMCSD_SPI_XFER(0xFF);
   /* begin initialization */
   i = 0;
   do
      delay_ms(1);
      mmcsd_select();
      r1 = mmcsd_go_idle_state();
      mmcsd_deselect();
      i++;
      if(i == 0xFF) {
         if (r1 == 0)
           return 1;
           return r1;
   } while(r1 != MMCSD_IDLE);
   i = 0;
   do
      delay_ms(1);
      mmcsd_select();
//!      r1 = mmcsd_send_op_cond();
      r1 = mmcsd_send_if_cond(r3);
      mmcsd_deselect();
      i++;
   } while((r1 & MMCSD_IDLE) && i != 0xFF);
   /* an mmc will return an 0x04 here */
   if(r1 == 0x04)
      g_card_type = MMC;
   else {
      g_card_type = SDSC;
      i = 0;
      do {
         r1=mmcsd_app_cmd();
         r1=mmcsd_sd_send_op_cond();
      } while (r1 == 0x01 && i != 0xFF);
      if (r1 == 0x01) {
         return r1;
      mmcsd_select();
      r1 = mmcsd_read_ocr(r3);
      mmcsd_deselect();
      if(r1 != MMCSD_ILLEGAL_CMD) {
        r1 = r3[3];
        if(bit_test(r1, 6))                  // If bit 30 of the OCR register is 1 (CCS is 1) ==> SDHC type
          g_card_type =  SDHC;
   /* set block length to 512 bytes */
   mmcsd_select();
   r1 = mmcsd_set_blocklen(MMCSD_MAX_BLOCK_SIZE);
   mmcsd_deselect();
   if(r1 != MMCSD_GOODEC)
     return r1;
   /// this would be a good time to set a higher clock speed, 20MHz
   to_spi_m0f();
   // Turn OFF CRC check, some card return 0 (MMCSD_GOODEC) and some others return 0x04 (MMCSD_ILLEGAL_CMD)
   mmcsd_select();
   r1 = mmcsd_crc_on_off(FALSE);
   mmcsd_deselect();
   r1 = mmcsd_load_buffer();
   return MMCSD_GOODEC;
Through this section I get the expected responses, and the card is recognised as SDHC (it's a 4GB SD Card, which I tested on a Windows PC and seems to work fine; it was formatted to FAT32 using the "official" SD Card Formatter utility).
However, right after the call to mmcsd_init in fat_init,, there's a sequence of mmcsd_read_data calls that appear to work but read no data (all the variables pointed to remain at zero). The final one in the sequence (ec += mmcsd_read_data(offset_ + 0x3EC, 4, &Next_Free_Clust);) returns a 5, ending fat_init prematurely. As far as I can tell, this 5 originates as a response from a READ_SINGLE_BLOCK command deep within the read_data call.
Does anyone have any insight into the possible cause? It's my first time interfacing with an SD Card, so I might be missing some obvious stuff.
asmallri
PostPosted: Mon Jun 29, 2026 8:22 pm     Reply with quote
If this is your own hardware then the first step is to validate the hardware configuration. The most obvious are, do you have the correct pull-up resistors - (e.g. 10K pull-up on the cards SDO output and the CS line)?
Do you have a low ESR capacitor (Ceramic or tantalum capacitor around 10uF) as close as practical to the power pins of the SD card socket?
Regards, Andrew
mrtele
PostPosted: Tue Jun 30, 2026 7:54 am     Reply with quote
I don't think we have one actually, we'll be sure to add it for better stability.
In any case, I ended up testing the drivers from the pinned post. I had to make a number of modifications, but it seems to be working now (making directories, reading and writing some simple txt files). I'll post the files once I finish with some more tests.
