#use spi statements
SeeCwriter
#use spi statements
PostPosted: Tue Jun 02, 2026 11:47 am     Reply with quote
I have multiple SPI devices in my design. Can I configure the spi bus using #use spi, then when communicating with each device, have another #use spi statement that just sets the ENABLE pin to use before comm with each device?
For example:
// myheader.h
#use spi( MASTER, SPI2, MODE=0, BITS=8, STREAM=SPI_1)
// adc.c
 unsigned int8 ReadADC()
    #use spi(ENABLE=PIN_D0)
    unsigned int8 rData[2];
    spi_transfer_read(SPI_1, rData, 2);
// dac.c
void WriteDAC(unsigned int8 *wData, int8 NumBytes)
    #use spi(ENABLE=PIN_D1)
    spi_transfer_write(SPI_1, wData, NumBytes);
[/code]
PostPosted: Wed Jun 03, 2026 12:16 am     Reply with quote
What you do is setup the same SPI, with two streams, and the different
enable settings:
#use spi( MASTER, SPI2, MODE=0, BITS=8,ENABLE=PIN_D0,STREAM=SPI_1D0)
#use spi( MASTER, SPI2, MODE=0, BITS=8,ENABLE=PIN_D1,STREAM=SPI_1D1)
Then use the stream names in the different transfers.
You can use different modes, and other options this way.
SeeCwriter
PostPosted: Wed Jun 03, 2026 11:00 am     Reply with quote
That's even better. I thought the most recent #use statement was the one that was used.
Thanks.
PostPosted: Wed Jun 03, 2026 11:05 am     Reply with quote
That's the whole point about stream names.
Very Happy
I use two spi streams set to different speeds on the same port this way.
jeremiah
PostPosted: Wed Jun 03, 2026 11:22 am     Reply with quote
Thanks.
It does for any initialization code. But for any code generated after initialization, the stream name will tailor the generated code.
