16F630 Clock Accuracy
Mark Weir
PostPosted: Mon Mar 29, 2004 7:12 pm     Reply with quote
Has anyone experimented with 16F630 using internal clock and the delay_ms command?
I am attempting to create a reliable 10 second then 3 second then 3 minute delay but the results are quite variable.
Can anyone shed any light on why?
Mark
Haplo
PostPosted: Mon Mar 29, 2004 8:03 pm     Reply with quote
Are you calibrating the internal oscillator? Quoting from the datasheet:
When calibrated, the internal oscillator provides a fixed
4 MHz (nominal) system clock...
A calibration instruction is programmed into the last
location of program memory. This instruction is a
RETLW XX, where the literal is the calibration value.
The literal is placed in the OSCCAL register to set the
calibration of the internal oscillator. Example 9-1
demonstrates how to calibrate the internal oscillator.
For best operation, decouple (with capacitance) VDD
and VSS as close to the device as possible.
Note: Erasing the device will also erase the preprogrammed
internal calibration value for
the internal oscillator. The calibration value
must be saved prior to erasing part as
specified in the PIC16F630/676 Programming
specification. Microchip Development
Tools maintain all calibration bits to
factory settings.
EXAMPLE 9-1: CALIBRATING THE
INTERNAL OSCILLATOR:
bsf STATUS, RP0 ;Bank 1
call 3FFh ;Get the cal value
movwf OSCCAL ;Calibrate
bcf STATUS, RP0 ;Bank 0
Also take a look at Electrical Specifications in the device datasheet (Section 12.0) for information on variation over voltage and temperature.
