		| Author | Message |
		| JerryR
				| CCS SMT example builds but does verify |
				|  Posted: Tue Sep 09, 2025 8:17 am |   |
				| Hello Group:
 I have been experimenting with the SMT peripheral and started with the CCS example "ex_smt_period_duty.c". The only edit I made to this example is I'm using a PIC16F1619 instead of a PIC16F1618, so I used the appropriate include file.
 I'm using CCS PCWH 5.120 to build. CCS ICD-U80 as debugger/programmer. Target is my design and programs, verifies, and runs with any other code.
 The code builds correctly, but does not verify unless I comment out the two SMT-related interrupts.
 CCSLoad reports correct voltage, and matched PIC devices. I have tried erasing manually with CCSLoad, same results, no verify.
 Here's the code:
  	  | Code: |  	  |
 #include <16F1619.h>   //Changed from 16F1618
 #define SMT_INPUT    PIN_C1
 #use delay(internal=8MHz)
 #pin_select U1TX=PIN_C6
 #pin_select U1RX=PIN_C7
 //#use rs232(icd, baud=9600)  //Text though the ICD
 #use rs232(UART1, baud=9600) //Text through the UART
 #pin_select SMT1SIG=SMT_INPUT
 unsigned int32 SignalDuty;
 unsigned int32 SignalPeriod;
 int1 NewCapture = FALSE;
 /*                     Programs and verifies when commented out
 #INT_SMT1PRA
 void period_isr(void)
 SignalPeriod = smt1_read(SMT_CAPTURED_PERIOD_REG); //read captured period
 NewCapture = TRUE;
 #INT_SMT1PWA
 void duty_isr(void)
 SignalDuty = smt1_read(SMT_CAPTURED_PULSE_WIDTH_REG); //read captured duty
 char* CalculatePeriod(void)
 static char str[10];
 float period;
 int8 t = 0;
 int8 Count;
 period = (float)SignalPeriod * (1.0 / (float)getenv("CLOCK"));
 while(period < 1)
 period *= 1000.0;
 t++;
 Count = sprintf(str, "%0.2f ", period);
 switch(t)
 case 0:
 sprintf(&str[Count], "s");
 case 1:
 sprintf(&str[Count], "ms");
 case 2:
 sprintf(&str[Count], "us");
 default:
 sprintf(&str[Count], "ns");
 return(str);
 float CalculateDuty(void)
 float duty;
 duty = ((float)SignalDuty * 100.0) / (float)SignalPeriod;
 return(duty);
 printf("\r\nex_smt_period_duty.c - %s\r\n\n", getenv("DEVICE"));
 //setup SMT1 for Period and Duty Cycle Acquisition Mode, Input signal on SMT1SIG pin
 setup_smt1(SMT_ENABLED | SMT_MODE_PERIOD_DUTY_CYCLE_ACQ | SMT_CLK_FOSC | SMT_SIG_INPUT_SMTSIGx);
 enable_interrupts(INT_SMT1PRA);  //enable SMT1PRA interrupt to capture period
 enable_interrupts(INT_SMT1PWA);  //enable SMT1PWA interrupt to capture duty
 smt1_start();  //start SMT1
 if(NewCapture)
 printf("\r\nSignal Period: %s, Duty: %0.2f%%", CalculatePeriod(), CalculateDuty());
 NewCapture = FALSE;
 smt1_start();  //re-start SMT1
 Any thoughts are much appreciated!!
		| temtronic
				|  Posted: Wed Sep 10, 2025 5:28 am |   |
				| While I don't use them ,I am curious... so I had a quik look at the 1618 and 1619... both have SMT and seem 'similar'....
 Does the code verify with the 1618 PIC ?
 Maybe look at the headers, compare and see if there's something 'different' about the 'SMT' sections ? I'd think they should be 100% the same ?
		| JerryR
				|  Posted: Wed Sep 10, 2025 6:02 am |   |
				| Thanks for considering my post Temtronic!
 I don't have a 1618 target to test verification, that would be a great experiment, however.
 I do know if I just comment out the interrupts associated with the SMT, it builds and verifies. In all cases the code builds. When verification takes place, after programing, there is code there, just not what's expected.
 Must have something to do with where the build places the interrupts. That's a great suggestion to check the device's header against the 1618.
 Again, I appreciate your help!
		| JerryR
				|  Posted: Wed Sep 10, 2025 6:03 am |   |
		| Ttelmah
				|  Posted: Wed Sep 10, 2025 11:04 am |   |
				| Could you try going back to some older firmware on the ICD?. There have been a number of issues with the latest updates to some of
 the CCS ICD units not programming some chips/features correctly.
 In the device editor, it might be worth trying changing the programming
 method option. There are a lot of different options, and the more basic
 options sometime work, but are slow, while the faster options are the ones
 that are having problems.
 It really does sound like a programming issue affecting some specific
 part of the program memory, or some specific instruction.
 It may only be a read problem. Does the code work if you disable verify?.
 Have you tried with other interrupts enabled/present?. You might just
 have a chip with a memory fault in the area used when the interrupts
 are present.
 I would suggest you talk to CCS about this. They seem to have been
 tweaking the programming algorithms recently, and they are faster, but
 seem to be giving a lot of issues.
		| JerryR
				|  Posted: Wed Sep 10, 2025 11:59 am |   |
				| Hi Ttelmah:
 Thanks for your interest!
 Well, I do know that the code mismatches as far down as I can see after programming and I can get other code working well on the same target. Also, code does run if I compile and program with the two interrupts commented out.
 I only have one ICD-U80, but it does seem to program other targets using different processors well.  I do have several Microchip debuggers and programmers, but have really never been able to get CCS IDE to work with them.
 To your suggestion, I'll try programming the troublesome target using Microchip  Studio or an old version of MPLAB 8x before involving CCS.  If I can successfully program with Microchip tools, I'll speak with CCS.
 Thanks again my friend
		| Ttelmah
				|  Posted: Thu Sep 11, 2025 10:07 am |   |
				| You missed part of what I suggested. Trying with another interrupt enabled and coded. Has any of the other code you are trying got any
 interrupts in use?.
		| JerryR
				|  Posted: Thu Sep 11, 2025 10:53 am |   |
				| Yes!  Absolutely, will do, thanks for the suggestion. I should be able to get back to this project early next week.
 What's your theory? Vectors in wrong place? Sounds like a good learning experience.
 Thanks again!
		| JerryR
				|  Posted: Sat Sep 13, 2025 10:02 am |   |
				| Ttelmah:
 To answer your question regarding adding any other interrupt. Yes, adding a Timer0 interrupt also causes a program not to verify.
 I'll troubleshoot further next week.
 Thanks,
 Jerry
		| sandyw
				|  Posted: Wed Sep 17, 2025 2:27 am |   |
				| Hello JerryR and Ttelmah,
 Just wondering if there is any update on this is as I think I am seeing the same thing with my code.
 I'm using:
 CCS compiler Vers 5.116,
 ICD U80 Firmware 3.64
 PIC processor pic16F18146
 I have programmed in an absolute minimum program shown
 < Header File>
 #include <16F18146.h>
 #fuses NOLVP
 #device ADC=12 ICD=true
 #use delay(internal=16000000)
 #define LED PIN_C7
 #define DELAY 1000
 <Main file>
 #include <main.h>
 //Example blinking LED program
 output_low(LED);
 delay_ms(DELAY);
 output_high(LED);
 delay_ms(DELAY);
 //TODO: User Code
 #int_timer1
 void timer1_isr(void)
 It will compile and run with out the interrupt routine directive. As soon an you include the #int_timer1 it fails to verify. It is not unique to the #int_timer1 directive. It fails to verify with all of the #Int_XXXX I've tried including int_rda, int_timer0, int_ext.
 Any news  on your problem JerryR
 Ttelmah you said "In the device editor, it might be worth trying changing the programming method option." Not sure what you mean by this, how do you change the programming method option?
 Thanks for any help
 SandyW
		| sandyw
				|  Posted: Wed Sep 17, 2025 6:42 am |   |
				| Some more information.
 I am using exactly the same set up as before but now programming our usual micro the pic18f8722 and everything is working as normal.
 SandyW
		| JerryR
				|  Posted: Wed Sep 17, 2025 7:51 am |   |
				| sandyw, Ttelmah:
 Well, I solved the issue, but am still very puzzled by the solution.
 After, closely examining my power supply with a scope, I noticed, that if I compiled the code with any interrupts coded in, the power at the microcontroller's Vdd pin, became slightly more noisey during programming verification. Why, I hadve no idea, except to believe the code begins to run at verification.
 To sove the issue, I placed an additional 10uF tant at the controller's Vdd pin in addition to the 0.1uF already there. I assume that the controller might draw a bit more current with the interrupts coded in. Just a guess.
 In years of PICing, I have never experienced this before. I'm open to further study, but I'm moving ahead with the project.
 When in doubt add a bigger bucket of charge to the controller.
		| sandyw
				|  Posted: Wed Sep 17, 2025 8:04 am |   |
				| JerryR,
 Thanks for the Reply. I'll give it a go and see.
 Sandy
		| temtronic
				|  Posted: Wed Sep 17, 2025 2:45 pm |   |
				| Ouch... you added a tantalum cap ??? I had several of them 'meltdown' decades ago on a very pricey custom PCB ( $2500). nasty little blobs.... Heard they can be 'troublesome'.
 Since then, just use 'standard aluminum' caps.....
 I also design PSU to be x10 the nominal rated current( say 1 amp.... use a 10 amp PSU ). Firm believer in 'over kill', saves the headache of trying to troubleshoot at 3 AM. Also allows for that  'just two more LEDs' to be added without 'weird' stuff happening !
		| sandyw
				|  Posted: Thu Sep 18, 2025 1:37 am |   |
				| All good info, thanks
 SandyW
