JP
| Write program code (.hex) to external EEProm or Flash |
Posted: Sun Mar 28, 2004 12:24 pm |
Hello all,
I have a litle question; I need to write my C source code to a
EEProm ( or Flash ) with a EEProm / FLash programmer.
For make this, I need the .hex file of my program code but
what is the means for obtain this file directly with PCWH 3.182 ?
Thank You for your help,
J-P |
Neutone
Posted: Sun Mar 28, 2004 12:27 pm |
| Compile |
JP
| Re Compile |
Posted: Sun Mar 28, 2004 12:53 pm |
Hi Neutone,
I have take a look at your Index page but I have no view a topic
about Compile ?
Can You tel me more ?
Thank You,
J-P |
JP
Posted: Sun Mar 28, 2004 1:25 pm |
Hi Neutone,
So, I interpreted your answer badly
You are right, after I execute the " Compile " command, the compiler
generate a file with the .hex format but under Windows, this file
is of ICD type ( but under the Dos, this is been the .HEX format ).
Thank You,
J-P
rwyoung
Posted: Sun Mar 28, 2004 1:52 pm |
The IDE "compile" command will generate a HEX file. You can fiddle with the Options | File Formats feature to specify what kind of HEX file. _________________ Rob Young
JP
Posted: Sun Mar 28, 2004 5:39 pm |
Hello Rob,
Yes, I have find this option.
Thank You !
