Compiler single step problems with V3.182
Javed Shafi
PostPosted: Thu Mar 18, 2004 8:04 am     Reply with quote
I am having problem running my compiler in Single Step mode, I have a for loop that is executed 10 times before exiting but in single step mode it runs only once. The loop counter goes from 0 to 10 missing the values in between. This could by explained if I was using Step Over but I am not the version of the compiler 3.182
Anybody encountered such problems before.
Haplo
PostPosted: Thu Mar 25, 2004 9:43 pm     Reply with quote
Are you using MPLAB IDE or PCW? Does the loop work fine when you step through the generated assembly code instead of the C code?
