Please help with the LCD example EX_LCDKB
carlosma
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Mar 24, 2004 5:16 pm     Reply with quote
I am new to this CCS compiler.
I tried the ex_lcdkb.c example listed below on my
ccs software (with 16F877). I connected
the 3x4 keyboard and 16x2 LCD with experience board
My platform includes the ccs C compiler, MPLAB IDE 6.0
connected with the experience board. I compiled the
code and programed 16F877 and run the example.
I failed to see anything on the LCD. Do I miss
anything? Thanks for your help.
Carlos Araújo
cmmaraujo@sapo.pt
portugal
PostPosted: Wed Mar 24, 2004 6:27 pm     Reply with quote
What port is the LCD connected to ? Is it Port B ?
If so, then you need to add a #define statement to
the EX_LCDKB.C file. Put it just above the #include
statement for lcd.c. Example:
#define use_portb_lcd  TRUE     // Add this line
#include <lcd.c>
#include <kbd.c>
Do this only if you are using Port B for the LCD.
If you are using Port D, then don't add that line.
Also, do you have a 10K trimpot on pin 3 of the LCD,
for contrast adjustment ? One end of the trimpot should
connect to +5v, and the other end to Ground. The tap
should go to pin 3 on the LCD. Set the trimpot so that
pin 3 is at +0.425 volts. This should set the contrast
to a good initial value. You should see characters now.
carlosma
PostPosted: Thu Mar 25, 2004 2:35 am     Reply with quote
Keyboard at Port B
LCD Port D
and
ON KBD.C
// Un-comment the following define to use port B
#define use_portb_kbd TRUE
