cfernandez
| Keypad Problem in 18F8720 |
Posted: Tue Mar 23, 2004 2:41 pm |
In my circuit I connect a keypad (4x3) on PORT E and not is possible to work.
The pinout is:
E0 NC
E1 COL0
E2 COL1
E3 COL2
E4 ROW0
E5 ROW1
E6 ROW2
E7 ROW3
In the circuit i connect pull up resistor the 10 k value.
Is possible that the PORT E is not use for this job?? or which is the solution for my problem.
Thank you very much |
mystery Guest
| port e |
Posted: Tue Mar 23, 2004 3:14 pm |
having looked at the datasheet, port e is the data bus for external memory.
if you want to use port e as normal pins you need to:
set bit 7 of memcon register!!!!!!!!! |
picker
| Keypad and 18F8720 |
Posted: Wed Mar 24, 2004 11:20 am |
Did you use the CCS driver for a keypad? If you did, you have run into the same problem that I had some months ago. It has something to do with the driver. I ended up writing a much simpler driver which might use more program memory but it works!
Picker |
cfernandez
Posted: Wed Mar 24, 2004 5:59 pm |
I modify KBD.C from CCS drivers and put in the kbd_init() set_bit( MEMCOM, 7), previous declare #byte MEMCOM= 0xF9C and not WORK!!
This the KBD.C code
//// KBDD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
////////////////// The following defines the keypad layout on port D
// Un-comment the following define to use port B
// #define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#byte kbd = 0xF84 // This puts the entire structure
#byte MEMCOM = 0xF9C
#define set_tris_kbd(x) set_tris_e(x)
//Keypad connection: (for example column 0 is B2)
// Bx:
#ifdef blue_keypad ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
#endif
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2)
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init() {
bit_set( MEMCOM, 7)
char kbd_getc( ) {
static BYTE kbd_call_count;
static short int kbd_down;
static char last_key;
static BYTE col;
BYTE kchar;
BYTE row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
switch (col) {
case 0 : set_tris_kbd(ALL_PINS&~COL0);
kbd=~COL0&ALL_PINS;
case 1 : set_tris_kbd(ALL_PINS&~COL1);
kbd=~COL1&ALL_PINS;
case 2 : set_tris_kbd(ALL_PINS&~COL2);
kbd=~COL2&ALL_PINS;
if(kbd_down) {
if((kbd & (ALL_ROWS))==(ALL_ROWS)) {
kbd_down=FALSE;
kchar=last_key;
last_key='\0';
} else {
if((kbd & (ALL_ROWS))!=(ALL_ROWS)) {
if((kbd & ROW0)==0)
row=0;
else if((kbd & ROW1)==0)
row=1;
else if((kbd & ROW2)==0)
row=2;
else if((kbd & ROW3)==0)
row=3;
last_key =KEYS[row][col];
kbd_down = TRUE;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
set_tris_kbd(ALL_PINS);
return(kchar);
ANY SOLUTION?????????
Thanks, |
