dazlogan
Joined: 19 Oct 2003 Posts: 24 Location: Cambridge, UK
Posted: Tue Mar 23, 2004 5:32 pm |
Hello again,
Can someone please send me the files:
CE51X.C
CE62X.C
CE67X.C
Thanks.
I seem to be missing them?!
Regards,
Darren |
dyeatman
Posted: Tue Mar 23, 2004 5:37 pm |
As I said in the other post. If you have a REGISTERED copy and the files were in your version then CCS will likely help you get them.
I would prefer not to violate my software license agreement since I have no way of knowing if you have a licensed copy or pirated version. |
dazlogan
| 8-) |
Posted: Tue Mar 23, 2004 5:50 pm |
ok, i'll give them a try but I can't see a justification in upgrading the compiler (i.e. a cost) if all that is required is a couple of text files!?
i bought the compiler back when it was version 2.1'something, many years ago
they were good enough to upgrade me to 3.0, then helped out with a couple of more recent versions when i was bogged down in bugs
Regards,
Darren |
Posted: Tue Mar 23, 2004 6:38 pm |
Actually the code for the CE519 is already on the forum.
So we can all be on the up and up.
http://www.ccsinfo.com/forum/viewtopic.php?t=12691
He has made one change to CCS's driver, by initializing
SCL to a high level instead of a low level. He has noted
that in his post. |
dazlogan
| 8-)) |
Posted: Tue Mar 23, 2004 6:52 pm |
Superb thank you!.
(I should have looked myself but didn't think it would be posted on here).
Regards,
Darren |
