allenhuffman
Joined: 17 Jun 2019 Posts: 621 Location: Des Moines, Iowa, USA
Posted: Thu Dec 19, 2024 11:22 am |
jeremiah wrote: | Out of curiosity, did you try PROGRAM_MEMORY and see how it compared to the other options? |
I have, now, and ran into a compiler issue (see other post I just made) which CCS is looking at.
But...
Code: | PROGRAM_MEMORY : 0xabfc (44028)
CONFIGURATION_ADDR. : 0x57f8 (22520)
Looks like CONFIGURATION_ADDR is giving the PIC24 memory location and PROGRAM_MEMORY is giving number of bytes. But converting that to 2-bytes per address is still not the same as CONFIGURATION_ADDRESS.
However, PROGRAM_MEMORY is the value our code hard-codes in a #define, so maybe that's enough. I'll check our two other PIC24 types and see if they confirm. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
allenhuffman
Posted: Thu Dec 19, 2024 11:35 am |
More tests:
24FJ256GA106:
PROGRAM_MEMORY : 0x2abf8 (175096)
CONFIGURATION_ADDR. : 0x557f0 (350192)
RAM : 0x3fa6 (16294)
FLASH_WRITE_SIZE : 0x100 (256)
MIN_FLASH_WRITE : 0x4 (4)
FLASH_ERASE_SIZE : 0x800 (2048)
BYTES_PER_ADDRESS : 0x2 (2)
BITS_PER_INSTRUCTION: 0x18 (24)
24EP256GP202:
PROGRAM_MEMORY : 0x2afec (176108)
CONFIGURATION_ADDR. : 0x55fd8 (352216)
RAM : 0x7fa6 (32678)
FLASH_WRITE_SIZE : 0x8 (8)
FLASH_ERASE_SIZE : 0x1000 (4096)
24FJ64GA002:
RAM : 0x1fa6 (8102)
allenhuffman
Posted: Thu Dec 19, 2024 11:49 am |
Looking at the data sheets at the Configuration Byte addresses:
1) 24FJ256GA106
1. 2ABFE
2. 2ABFC
3. 2ABFA
We use 0x2ABF8 (half of what CONFIGURATION_ADDRESS reports. Not matching data sheet?
2) 24EP256GP202
Range: 2AFEC -- 2AFFE
We use 0x2AFF0 (half of CONFIGURATION_ADDRESS is 2AFEC, which matches the data sheet)
3) 24FJ64GA002
1. ABFE
2. ABFC
We use 0xABFC (matches CONFIGURATION_ADDRESS, and word #2 in the data sheet)
#3 is the only one where the #define in our code matches the datasheet. I expect there is a reason, but for now I may just leave everything as-is since it's been that way for well over 6 years. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Thu Dec 19, 2024 12:08 pm |
And I now understand... The #defines we use match what is in the CCS HEX files.
Either CCS is wrong (well, it all seems to work, so probably not), or the data sheet is wrong (one of them has an update where they specifically corrected a Configuration Byte address so they have been in the past, at least), or CCS is wrong with what CONFIGURATION_ADDRESS returns from their database
Clear as mud. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Thu Dec 19, 2024 12:15 pm |
Some more details:
1 - 24FJ256GA106:
CCS HEX file uses 2ABF8
Configuration Words
02ABF8: 00FF0000 00FFFFFF 00FF8319 00FF3F4D
Program Memory
Data sheet does not match - it shows (Word1) 2ABFE, (Word2) 2ABFC and (Word3) 2ABFA
2 - 24EP256GP202:
CCS HEX file uses 2AFF0
Configuration Words
02AFF0: 00FFFFCF 00FFFFEF 00FFFF6D 00FFFF39
02AFF8: 00FFFFF8 00FFFFFF 00FFFFFF 00FFFFFF
Program Memory
Data sheet does not match? Range of 2AFEC-2AFFE???
3 - 24FJ64GA002:
CCS HEX file uses ABFC
Configuration Words
00ABFC: 00FFFB15 00FF3F6D
Program Memory
Data sheet lists Word2 ABFC (match) and Word1 (ABFE). _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Thu Dec 19, 2024 12:28 pm |
I really need to write this up on my blog.
getenv("PROGRAM_MEMORY")
24FJ256GA106: 256K/16K - 87K Instructions
(divide by two and get 87548 instructions. 3-bytes per would be 262644, 256K-ish)
24EP256GP202: 256K/32K - 88K Instructions
(divide by two and get 88054 instructions. 3-bytes per would be 264162, 257K-ish)
24FJ64GA002: 64K/8K - 22K Instructions
(divide by two and get 22014 instructions. 3-bytes per would be 66042, 64K-ish). _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
