PIC24F Clock frequency multiply problem
Mrinmoy
View user's profile Send private message Send e-mail AIM Address
PostPosted: Fri Sep 20, 2024 1:40 am     Reply with quote
Hi Everyone,
I am using PIC24FJ512GL406 mcu in one of my project and using 32MHz external oscillator and want to double the clock frequency by using PLL.
//********* CPU Settings *******************************************
#device ICSP = 1
#pragma use delay(osc=32000000,clock=64000000,restart_wdt,clock_out)
#pragma fuses NOPROTECT,WDT,NOBROWNOUT,DEBUG,CKSNOFSM
This is my system setup code but not working.
If I change my line like -
#pragma use delay(clock=64MHz,osc,restart_wdt,clock_out)
Then the code will run but timer is not matching with 64MHz calculation and also clock out PIN shows 16MHz.
Any help will be highly appreciated.
Thanks in advance Very Happy [/code]
PostPosted: Fri Sep 20, 2024 3:59 am     Reply with quote
The 16MHz, is right. Data sheet. CLKO = FOSC/2.
Are you sure what frequency you are running the timer off?. The timers by
default are run off the 'peripheral clock'. This is also FOSC/2. Look at
figure 9-1.
gaugeguy
PostPosted: Fri Sep 20, 2024 5:53 am     Reply with quote
With that processor, the CPU can only run at up to 32MHz. The PLL can be used to get 48MHz for the USB.
You cannot run the processor at 64MHz.
PostPosted: Sat Sep 21, 2024 12:21 am     Reply with quote
Spot on. Maximum CPU instruction speed is 16MHz. Max clock 32MHz.
Mrinmoy
PostPosted: Sat Sep 21, 2024 1:19 am     Reply with quote
Yes! I just check it.
CPU of that particular controller can run maximum at 16MHz.
Thanks guys. Very Happy
