janet
| DS1631 error |
Posted: Sat Mar 20, 2004 4:35 am |
I am using DS1631 driver from CCS. However, i always get t = 1E1E. I have check the datasheet from maxim-ic.com, it shows that the LSB must be always zero. Can you point me out where i did wrongly?
| Code: | #include "DS1631.C"
#include <math.h>
int16 t;
init_temp();
while(1) {
t = read_full_temp();
printf("\n\r t: %4LX \n\r", t);
getc();
Posted: Sat Mar 20, 2004 2:02 pm |
| Quote: | I am using DS1631 driver from CCS. However, i always get
the LSB must be always zero. Can you point me out where i did wrongly? |
You need to read the CCS driver file and the DS1631 data sheet more
closely. The CCS driver, DS1631.C, says that it returns the temperature
in degrees Fahrenheit, in hundredths. This means it returns the
degrees x 100.
For example, you got 0x1E1E. Convert that to decimal. It's 7710.
Divide that by 100. You get 77.1 degrees Fahrenheit. That's about
25 degrees Celsius.
Also, note that the CCS driver puts the Ds1631 in 12-bit mode.
This is explained in the data sheet, with a sample chart for that
mode in Table 4.
In your post, you implied that you wanted to see the raw data from
the DS1631. To do that, you need to modify the following routine
in the CCS driver. Comment out the conversion code, and add 1
line of code, as shown below.
| Code: | signed long read_full_temp() {
signed int datah, datal;
signed long data;
i2c_start();
i2c_write(0x90);
i2c_write(0xaa);
i2c_start();
i2c_write(0x91);
datah=i2c_read();
datal=i2c_read(0);
i2c_stop();
// Comment out the conversion to degrees Fahrenheit x 100.
// Now this function will return the raw data.
// data=(long)datah*100;
// data=data+(((datal >> 4 )*(long)50)/16);
// data=data*9;
// data = (data / 5) + 3200;
// return(data);
return( ((long)datah << 8) | (long)datal);
