DSPIC33EP512GP502 -- PCD v5.115 Bootloader UART issue
Goto page Previous  1, 2
PostPosted: Fri Jul 05, 2024 3:04 am     Reply with quote
Of course you can keep it in the application, but as I said, you do need an
enable_interrupts(GLOBAL), to allow it to work.
The point is that the bootloader re-vectors the interrupts to work in the
main code. You were overwriting this re-vectoring code by telling the
bootloader to use a buffer... :(
Marco27293
PostPosted: Fri Jul 05, 2024 3:12 am     Reply with quote
Thanks !!
Now it's working with Receive_buffer only in application.
Regards!
PostPosted: Fri Jul 05, 2024 5:16 am     Reply with quote
You may also find the size of the bootloader has reduced significantly.
The code to handle the buffer would be a large part of why the loader
was larger......
Page 2 of 2
