benoitstjean
Joined: 30 Oct 2007 Posts: 579 Location: Ottawa, Ontario, Canada
PIC24EP - PDM sampling / library to PCM |
Posted: Mon Mar 18, 2024 8:04 pm |
Hello again,
Anyone has a PIC library to sample and convert a PDM bitstream from a MEMS microphone to PCM (16-bit 16kHz or something equal or greater than to 8bit 8kHz)?
Thanks,
Ben |
Posted: Tue Mar 19, 2024 12:17 pm |
You are going to need a serious PIC. A lot of mahs involved, you have to
generate a LPF,, then use a decimate function. You need something with
a serious amount of RAM and processng speed. So a DsPIC probably. |
benoitstjean
Posted: Tue Mar 19, 2024 12:38 pm |
Hmmm.... Even if I'm running internally at 129.042MHz?
I found an ADI IC that does it but it's so small and it's a BGA, there's zero way for me to do solder it manually. I do 0402 by hand and some smaller stuff through a microscope but that ADI IC is way way way smaller at 1.3mm x 1.4mm, 9 pins, BGA.
I use a lot of the TLV320AIC3204 CODECs and in one of the manuals, there appears to be a PDM input for digital mics but there's no further explanation. I wrote to TI support and they're usually pretty good so I'll wait to see what they have to say.
Thanks!
Ben |
Joined: 01 Jul 2010 Posts: 9464 Location: Greensville,Ontario
Posted: Tue Mar 19, 2024 2:44 pm |
Hay Ben
Does ADI have a 'demo' PCB available ?
While it might be pricey, it'd be a god way to R&D to even see IF what you want to do is possible.
So last day of fall and I have SNOW here in hamilton.
arrgh, tonight Spring comes and the white better be GONE tomorrow ! |
benoitstjean
Posted: Wed Mar 20, 2024 10:27 am |
Yeah ADI has a kit, price is not the issue, soldering is the issue. The IC is so small AND it's BGA. Can't do it by hand. Anyhow, I currently use the TLV320AIC3204 and TI gave me pointers as to where to look on how to use it. It's a bit basic for information but I'll have a look.
Thanks. |
benoitstjean
Posted: Wed Mar 20, 2024 11:03 am |
In the 'dinosaur days', I tool a demo kit PCB and turned it into a 'daughter' board for a few projects.
Course back then stuff was a LOT bigger...and I could READ the part numbers of DIP Chips....
sigh.... |
