int32
mattmab
int32
PostPosted: Sat Mar 13, 2004 11:55 pm     Reply with quote
does anyone understand why this wont work? it seems i cant initialze leds to hex 4000.
thanks ahead - matt
#case
#include <16f876.h>
#device *=16 ICD=TRUE
#use delay( clock=11059000 )
int32 leds = 1;
leds = 0x4000;
Re: int32
PostPosted: Sun Mar 14, 2004 3:42 am     Reply with quote
thanks ahead - matt
#case
#include <16f876.h>
int32 leds = 1;
leds = 0x4000;
Should work. Try declaring the constant as a long - so:
leds= 0x4000L;
Sometimes the compiler is less than 'intelligent' about such things...
mattmab
int32a
PostPosted: Sun Mar 14, 2004 9:59 pm     Reply with quote
Sad Sad Sad
nope,4000L dont work either, it takes it as a 16 bit. it works if i use make32(), but that seems like a poor way. does 32 bit math work? i never checked...
thankws - matt
PostPosted: Sun Mar 14, 2004 10:51 pm     Reply with quote
It actually does work. If I take your code here,
#case
#include <16f876.h>
int32 leds = 1;
leds = 0x4000;
and compile it with PCM vs. 3.184, I get this result in the .LST file:
0011 01A3       00277 CLRF   23
0012 01A2       00278 CLRF   22
0013 3040       00279 MOVLW  40
0014 00A1       00280 MOVWF  21
0015 01A0       00281 CLRF   20
The symbol table shows that 'leds' is at address 0x20:
leds       00000020
The ASM code is setting the memory locations as follows:
0x23 = 0
0x22 = 0
0x21 = 0x40
0x20 = 0
Since CCS stores variables in Intel Lo-Hi format, this means
that 'leds' = 00 00 40 00 which is correct.
I suspect that the problem is in how you are viewing the 'leds' variable.
For example, if you're using printf, you need to specify the format
string as "%lx", and not "%x", in order to display a 16 or 32-bit number.
