LCD_PUTC command
asjad
LCD_PUTC command
PostPosted: Fri Mar 12, 2004 9:18 am     Reply with quote
Has anyone managed to get:
(a) Cursor to flash
(B )Create custom Characters
USING THE "LCD_PUTC" COMMAND????
Best Regards
Charlie U
PostPosted: Sun Mar 14, 2004 7:39 pm     Reply with quote
I use my own LCD functions, but they are close to the CCS functions. I have created custom characters for LCDs but unfortunately, the code belongs to my clients so I can't post it. Here's the concept: create another function that points the write to the CG ram. This CGRam starts at address 0x40, then just write out the pixel row data of the character by using 8 consecutive writes just like writing a character to the display except the data is the hex value for a row, not a character. Then point the LCD to the character position for the new character and write the character using the address where you previously created your custom character. It is fairly straight forward, once you decipher the LCD controller chip data sheet.
plehman
PostPosted: Sun Mar 14, 2004 9:30 pm     Reply with quote
To make the cursor show up on HD44780 or compatible LCD modules, I used
lcd_send_byte(0, 0x0F);   // Send Command to Show Cursor
To hide the cursor, use the following:
lcd_send_byte(0, 0x0C);   // Send Command to Hide Cursor
lcd_send_byte() is in the canned lcd.c module
