High Impedance
MCUprogrammer
High Impedance
PostPosted: Wed Mar 22, 2023 12:27 am     Reply with quote
When an input pin is in a high impedance (high-z) state, the pin's state cannot be known until that pin is connected to logic zero or logic one.
Well, in the project I am using now, I want to pull the D port, 8 bit data, to high impedance. How can I do that.
Best Regards...
MCUprogrammer
_______________________________
Work Hard
PostPosted: Wed Mar 22, 2023 2:43 am     Reply with quote
Your nomenclature is very strange.
A line can't be 'pulled' to high impedance. The point about a high impedance
line is that it is undriven. 'Floating'. No pulling involved. Now a lot of PIC's
do offer a relatively high impedance current source pull-up on some pins
(some of the later PIC's offer pull down as well). Details of this are dependant
on what PIC is involved. If this is what you want, look at the data sheet for
your chip to see if it is available on these pins. If it is, then look at:
port_x_pullups in the manual.
Depending on whether the chip supports individual pullups, or only 'whole
port', this either accepts a numeric value to specify the pattern of bits to
be set, or a simple TRUE/FALSE to turn the whole port on/off. On chips
that support pulldown, the command accepts a second value for these.
If you just want the pins to be high impedance, then just set them as
inputs with TRIS, or output_float.
MCUprogrammer
PostPosted: Wed Mar 22, 2023 4:42 am     Reply with quote
I just want the pins to be high impedance.
For example, set_tris_d(0xFF); I will do it. Is it true?
if i want to do it alone
output_float(PIN_D0);
output_float(PIN_D1);
output_float(PIN_D2);
output_float(PIN_D3);
output_float(PIN_D4);
output_float(PIN_D5);
output_float(PIN_D6);
output_float(PIN_D7);
pins will be idle to pull it to high impedance. There will be no PULL_UP or PULL_DOWN.
Best Regards...
MCUprogrammer
Work Hard
PostPosted: Wed Mar 22, 2023 5:11 am     Reply with quote
FWIW...
A few years ago ( OK ,probably 2 decades.....) Microchip penned an article on how to read the status of any pin that could be 'floated', giving you THREE results, high, low and hi-z.
It was in one of the 'Tips & Tricks' books. Yes, THAT long ago, when books were written... I have a copy of it here, somewhere.....
One very common use of 'float' is with Dallas 'one wire' products,
MCUprogrammer
PostPosted: Wed Mar 22, 2023 5:26 am     Reply with quote
@ temtronic si how many years have you been dealing with electronic software Smile
Best Regards...
MCUprogrammer
Work Hard
PrinceNai
PostPosted: Wed Mar 22, 2023 5:38 am     Reply with quote
I'd make a little correction here. If you read that pin with let's say input_state() and that pin isn't connected anywhere,you will still read either a 1 or a 0, but it will be a random nonsense value, result of a noise or even a proximity of your finger.
What can't be detected is that this pin is actually floating.
PostPosted: Wed Mar 22, 2023 5:52 am     Reply with quote
yes it can... google 'microchip tips & tricks'.1st hit, download the PDF, TIP #3, page 1-3.
BTW tip #10(generate high voltage) allows a 3 volt PIC to run a 5 volt LCD module.
There's lots of neat ways to maximize the power of a PIC in the book, everyone should have a copy and re-read it every few months.
FWIW been 'playing with PICs' since late '80s. I bought PCM v2.534. It came with a spiral bound manual. 1st client's product allowed me to retire in '91, so no more commercial interest now, just 'fun'.
PrinceNai
PostPosted: Wed Mar 22, 2023 5:54 am     Reply with quote
https://www.microchip.com/DS01146
Just found the book. I remembered (from 20 years ago) that some switching of the pin is needed.
gaugeguy
PostPosted: Wed Mar 22, 2023 6:00 am     Reply with quote
Yes, it relies on the capacitance of the pin to hold the pin voltage for a very short time.
MCUprogrammer
PostPosted: Wed Mar 22, 2023 6:07 am     Reply with quote
I understand. Thank you for all the information. When you retired, I came to the new world. wow.
Best Regards...
MCUprogrammer
Work Hard
PostPosted: Wed Mar 22, 2023 8:18 am     Reply with quote
thanks, make the 'dinosaur' feel older ! Smile
My first PICs had pretty quartz windows on top..allowed you to see the electrons moving about.... Wink
Since it took 15 minutes to erase them, it was a great excuse to grab another coffee, and another, and .....
PostPosted: Thu Mar 23, 2023 12:47 am     Reply with quote
But of course mosr erasers took six or even ten chips. The only time you
had to wait was when you were working with just one or two chips.
Worse though I remember before EEPROMs, when the chips were OTP
only. Got expensive....
PostPosted: Thu Mar 23, 2023 9:48 am     Reply with quote
sigh...OTP, like the 8223s I have here..
wonder if a PIC could replace them...?
I remember fully reloading diodes onto PDP-8 'boot boards', then snipping out one here, one there to reprogram the board. Wished I'd kept the true 'core' memory modules......hand sewn by women......
PostPosted: Thu Mar 23, 2023 3:34 pm     Reply with quote
Those memory "modules" were amazing at the time. I was a PDP jockey
when PDP8 core 64K boards cost $18-26K each. The RIM loader
procedure performed so many times it is burned into my brain is totally useless
now...:-(. I guess I am part of the dying breed that used to also repair the ASR-33
that went with it. Toggle in the RIM loader to read and boot the basic OS from
paper tape on the ASR33 which then read the application assembler code from
DEC dual cassette magnetic tape deck...we have it soooo good now!.
