LCD & 16F877....weird INIT behaviour !?!?!?!
Izolator
View user's profile Send private message ICQ Number
PostPosted: Fri Feb 27, 2004 2:20 pm     Reply with quote
Hi guys,
I have connected a HD77480 2x16 lcd to Pic 16F877.
Compiler: PCM 3.173
20Mhz Quartz
I experience weird behaviour after my lcd_init() functions has run through a clean main() as the only function besides the while(1). Problems include but are not limited to:
- a semi-visible/transparent grey-boxed line on line 1 (e.g. like a konstant curser all the way through line 1)
- nothing on display
Once in a while it will boot ok and work......even if I have several lcd_putc functions in main, like it is supposed to.
I tried to switch the EN and RS lines and that produces a VERY visible grey-boxed line on line 1.
I switched them back again and the behaviour mentioned first starts all over.
I have removed all code not nescesary but not my diretives, as I need them for later.
I'm all out of ideas :-(
I hope someone can tell me if the set_tris_x are in the correct places.
I suspect it is my timing of outputting stuff to the display during the lcd_init that does not entirely corespond to:
http://preterhuman.net/texts/computing/HardwareDIY/LCDFaq.txt
2.6.1
If someone would modify the code or point out excactly where I mess up, I would be most grateful.
#device PIC16F877 *=16
#include <16F877.h>
#include <F877.h>  // the file Microchip used to supply, with port def's etc.
#include <string.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,WRT
#use rs232(baud=9600,xmit=PIN_C6, rcv=PIN_C7)
#use I2C(master, sda=PIN_C4, scl=PIN_C3, slow, force_hw)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#bit LCD_RS = PORTA.3   // RA3
#bit LCD_RW = PORTA.2   // RA2
#bit LCD_EN = PORTA.1   // RA1
#byte LCD_DATA = PORTD   // PORTD
void lcd_init()
   byte i;
   SET_TRIS_A(0x00);         // set port A, output
   SET_TRIS_D(0x00);         // set port D, output
   LCD_RS = 0;
   LCD_RW = 0;
   delay_ms(15);
   for(i=1;i<=3;++i)         // init af LCD
      LCD_EN = 0;
      LCD_DATA=0b00111000;   //8 Bit Interface, 2 Lines
      delay_cycles(1);
      LCD_EN = 1;
      delay_ms(5);
                        // konfig af LCD
   lcd_write(0,0b00111000);   // 8 Bit Interface, 2 Lines
   lcd_write(0,0b00001101);   // Turn on display, cursor off, blink ON
   lcd_write(0,0x00000001);   // clear display
   lcd_write(0,0x00000110);   // Increment cursor
void lcd_gotoxy(byte x, byte y)
   byte address;
   if(y!=1)
   address=0x40;
   address=0;
   address+=x-1;
   lcd_write(0,0x80|address);
void lcd_putc(char c)
   switch (c)
      case '\f' :
         lcd_write(0,1);
      case '\n' :
         lcd_gotoxy(1,2);
      default :
         lcd_write(1,c);
byte lcd_read(void)
   byte word;
   SET_TRIS_D(0xFF);      // set port D as inputs
   delay_cycles(1);
   LCD_RW = 1;
   delay_cycles(1);
   LCD_EN = 1;
   delay_cycles(4);
   word = LCD_DATA;
   LCD_EN = 0;
   LCD_RW = 0;
   SET_TRIS_D(0x00);      //set port D as outputs
   return( word );
void lcd_write(byte address, byte b)
   LCD_EN = 0;
   LCD_RS = 0;
   delay_cycles(4);
   SET_TRIS_D(0xFF);      // set port D, input
   while ( bit_test(lcd_read(),7) ) ;
   LCD_RS = address;
   LCD_RW = 0;
   delay_cycles(1);
   LCD_DATA=b;
   delay_cycles(1);
   LCD_EN = 1;
   delay_cycles(4);
   LCD_EN = 0;
main()
lcd_init();
lcd_putc("\ftest");   // clears display with \f and writes test in line 1, as expected.
// I have tried with other text's like "test", "\f\ntest" ...etc., same problem.
while(1) {}
Best Regards
Rasmus 'Izolator'
Kasper
PostPosted: Fri Feb 27, 2004 2:47 pm     Reply with quote
double check with the lcd.c driver which shipped with the compiler. it may give you a hint
Izolator
PostPosted: Fri Feb 27, 2004 2:55 pm     Reply with quote
I'm a complete newie and I really need the features that my program offers. I looked at the lcd.c and it is for 4 line lcd, not my cup of tea.
I think my problems are related to the timing and was hoping others had used the code by mr. Troy Schultz, e.g. the lcd code I am using.
....any ideas ?
BR
Rasmus 'Izolator'
PostPosted: Fri Feb 27, 2004 3:14 pm     Reply with quote
Check if you have the LCD wired correctly. Go to the following
page, and click on some of the links at the bottom. Especially
look at the sections on Contrast control.
http://www.crystalfontz.com/forum/showthread.php?s=8b2fca0a105842afce0e2bf7804c1f7a&threadid=1288
Izolator
PostPosted: Fri Feb 27, 2004 3:34 pm     Reply with quote
I have it wired up ok, I guess:
LCD:Pic16F877
0: ground
1: +5V
3: -1.5V ( I got a potentiometer and steal the negative voltage from a maxim max233a, p10 => steady negative voltage)
4: pin5
5: pin6
6: pin4
7-14: D0-D7
15-16: not connected, backlight not present, I'm told
I dont have a scope, but I do have a voltmeter and I tested the pins, they are ok.
The problem is most notorious when it has been powered off for a few hours....weird.
Anyone else use the code posted who has had similar problems or solved them ?
BR
Rasmus 'Izolator'
chava
are you?...
PostPosted: Fri Feb 27, 2004 4:31 pm     Reply with quote
are you using picdem2 board?
I remember when I started using the lcd, i had problems (can't remember what problems..)
if your using the picdem2 board ,here is a code I use which WORK
you may change the pin defines to alter it for your own connection
hope it will help
//LCD   //////////////////////////////
// As defined in the following structure the pin connection is as follows:
//    pic      lcd
//     A1     enable
//     A2     rw
//     A3     rs
//     D0     D4
//     D1     D5
//     D2     D6
//     D3     D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
//***********************************************************#if defined(__PCH__)
   #byte lcd = 0xF83      // This puts the entire structure
#else
   #byte lcd = 8          // on to port D (at address 8)
//***********************************************************#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
/ /The following are used for setting
// the I/O port direction register.
//***** lcd command port  ******
struct lcd_command{
   char none:1;
   char enable:1;
   char read_write:1;//rw
   char data_command:1;//rs
struct lcd_command lcd_command_port;
#locate lcd_command_port=5
struct lcd_data{
   char data:4;
struct lcd_data lcd_data_port;
#locate lcd_data_port=8
//************  "COMMAND / DATA definition
#define COMMAND0 0
#define DATA1 1
//************  "READ / WRITE definition
#define WRITE0 0   //LCD <- MPU
#define READ1 1  //LCD -> MPU
//************  "E_UP / E_DOWN definition
#define E_DOWN 0
#define E_UP 1
//**********eeprom or flash*********************
#define EEPROM0 0   ;eeprom - not the program  memory
#define FLASH1 1   ;program memory
//*********  set tris d  *********
#define set_tris_lcd_read(){\
   set_tris_a(TRISA & 0xf1/*0b11110001*/);\
   set_tris_d(TRISD | 0x0f/*0b00001111*/);\
#define set_tris_lcd_write(){\
   set_tris_d(TRISD & 0xf0/*0b11110000*/);\
//***********   clear LCD  ***********************************
#define clear_lcd   lcd_send_byte(0x1,COMMAND0);//clear lcd display
char lcd_read_byte(void){
      char low,high;
      set_tris_lcd_read();
      lcd_command_port.read_write = READ1;
      delay_cycles(1);
      lcd_command_port.enable = E_UP;
      delay_cycles(1);
      high = lcd_data_port.data & 0x0f;
      lcd_command_port.enable = E_DOWN;
      delay_cycles(1);
      delay_us(1);
      low = lcd_data_port.data & 0x0f;
      set_tris_lcd_write();
      return( (high << 4) | low);
void lcd_write_nibble(char temp_wr){
//Purpose:
      lcd_data_port.data = temp_wr;
      delay_cycles(1);
      lcd_command_port.enable = 1;
      delay_us(2);
      lcd_command_port.enable = 0;
void lcd_send_byte(char data , char data_or_command ) {
      lcd_command_port.data_command = COMMAND0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd_command_port.data_command = data_or_command;
      delay_cycles(1);
      lcd_command_port.read_write = WRITE0;
      delay_cycles(1);
      lcd_write_nibble(data >> 4);
      lcd_write_nibble(data & 0xf);
void lcd_gotoxy( char location, char line) {//location 0...
   char address;
   if(line!=1)
     address=40;//was80
     address=0;
   address+=location;
   lcd_send_byte(0x80|address,COMMAND0);
//********** -  1 -
void lcd_init(void){
//Purpose: initiate the lcd
   //turnning PORTA0=analog, PORTA1-7=digital
   ADCON1=0x0e;
   //turnning command pin of lcd to output
   //delay 15msec
   delay_ms(15);
   lcd_command_port.enable=0;
   lcd_command_port.data_command=0;
   lcd_command_port.read_write=0;
   lcd_data_port.data=0;
   delay_ms(2);
   lcd_write_nibble(0x03);//was 30  ddram address: 1:1bit,line:1bit,address:4bit
   delay_ms(10);//more then 4.1msec
   delay_us(150);//more then 100usec
   delay_us(100);
   lcd_write_nibble(0x02);//was 20
   while(bit_test(lcd_read_byte(),7));
   lcd_send_byte(0x28,COMMAND0);
   //  4 bit low nibble, ddram address=0 first line
   lcd_send_byte(0x0c,COMMAND0);//disp on
   clear_lcd;
   lcd_send_byte(0x6,COMMAND0);//entry inc
   lcd_gotoxy(1,1);
void lcd_putc( char c) {//this function works good
   switch (c) {
     case '\f'   : lcd_send_byte(1,COMMAND0);   delay_ms(2);   break;   //Clear display
     case '\n'   : lcd_gotoxy(1,2);                        break;   //Go to start of second line
     case '\b'   : lcd_send_byte(0x10,COMMAND0);               break;   //Move back one position
     default     : lcd_send_byte(c,DATA1);                  break;   //send the actual character
char lcd_getc( char location, char line) {
      char value;
    lcd_gotoxy(location,line);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd_command_port.data_command=1;
    value = lcd_read_byte();
    return(value);
      return 1;
void lcd_put_string(char *string){
//put string, starting  from the curren cursor position
//assume that string not excides from lcd displayed RAM
   char index=0;
   while(string[index]!=0){
      lcd_putc(string[index++]);
Izolator
PostPosted: Fri Feb 27, 2004 4:37 pm     Reply with quote
Problem solved, it seems:
   LCD_EN = 0;
   LCD_RS = 0;
   delay_cycles(4);
 //  SET_TRIS_D(0xFF);      <= problem line, allready tris'ed input in lcd_read
//   SET_TRIS_A(0x00);      <= problem line, allready tris'ed output in lcd_read
   LCD_RS = address;
   LCD_RW = 0;
   delay_cycles(1);
   LCD_DATA=b;
   delay_cycles(1);
   LCD_EN = 1;
   delay_cycles(4);
   LCD_EN = 0;
Apparently setting the same tris as the port direction already has is not a good idea.....or that is my theory, because it works now :-)
Thankyou for your time guys, I was about to panick Shocked
...taught me to check the tris before asking again Very Happy
BR
Rasmus 'Izolator'
PostPosted: Mon Mar 01, 2004 6:33 pm     Reply with quote
while were on the topic,
could anybody tell me which is easier to use a parallel or serial LCD.
if anybody has some sample code for displaying on a serial LCD, from a 16f877
if you could mail it to kitedude@kitedemon.com it would be much appreciated.
Brian
treitmey
PostPosted: Tue Mar 02, 2004 9:55 am     Reply with quote
Here is the PICDEM2 PLUS driver I came up with.
////                 PICDEM2_LCD.C                                 ////
////                 Driver for common PICDEM2 PLUS LCD modules        ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
#define use_PICDEM2_lcd TRUE
#if defined use_PICDEM2_lcd
   #define  lcd_en  PIN_A1
   #define  lcd_rw  PIN_A2
   #define  lcd_rs  PIN_A3
   #define  d_cycle 1
void lcd_send_nibble( BYTE n ) {
   n=n&0x0f; //Strip off the top 4 bits.. This only sends bit 3:0
   output_d(n);
   delay_cycles(d_cycle);
   output_high(lcd_en);
   delay_us(20);
   output_low(lcd_en);
BYTE lcd_read_byte() {
   BYTE low,high;
   output_high(lcd_rw);
   high = input_d(); //using d0:d3 for 4 bit data bus
   output_low(lcd_en);
   delay_us(1);
   low = input_d(); //using d0:d3 for 4 bit data bus
   output_low(lcd_en);
   return((high<<4) | low);
void lcd_send_byte( BYTE A0, BYTE n ) {    //A0:  0=instruction, 1=Data
   output_low(lcd_rs);
   while ( bit_test(lcd_read_byte(),7) ) ; // wait until busy flag is low
   if (A0==0){ output_low(lcd_rs);} //0=Instruction  and 1=Data
   if (A0==1){output_high(lcd_rs);} //0=Instruction  and 1=Data
   output_low(lcd_rw);
   output_low(lcd_en);
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
void lcd_init() {
   BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
   // These bytes need to be sent to the LCD for initialization.
   BYTE i;
   fprintf(debug,"Init!!\n\r");
   output_low(lcd_rs);
   output_low(lcd_rw);
   output_low(lcd_en);
   delay_ms(15);
   for(i=1;i<=3;++i) {
      lcd_send_nibble(3);
      delay_ms(5);
   lcd_send_nibble(2);
   for(i=0;i<=3;++i){
      lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE Data;
   if(y!=1)
      Data=lcd_line_two;
      Data=0;
   Data+=x-1;
   lcd_send_byte(0,0x80|Data);
   switch (c) {
      case '\f'   :
         lcd_send_byte(0,1);
         delay_ms(2);
      case '\n'   :
         lcd_gotoxy(1,2);
      case '\b'   :
         lcd_send_byte(0,0x10);
      default     :
         lcd_send_byte(1,c);
char lcd_getc( BYTE x, BYTE y) {
   char value;
   lcd_gotoxy(x,y);
   output_low(lcd_rs);
   return(value);
Also double check that the circuit doesn't need any pull-up resisters.
treitmey
PostPosted: Tue Mar 02, 2004 9:57 am     Reply with quote
Opps,.. you wanted code for a serial LCD,... This was 4 bit parallel
PostPosted: Wed Mar 10, 2004 6:43 pm     Reply with quote
the problem with the ide board is that pin 39 and 40 ar enot connected to the board so they can not be used.
the lcd.cd supplied with ccs uses these ports and hence has to be modified before its used
