i2c_write_slave
reesesm2000
i2c_write_slave
PostPosted: Thu Oct 13, 2022 2:46 pm     Reply with quote
I found this comment in the Recent Changes page.
5.089 Added a new i2c_write_slave() function so slaves can push data to the master in an ISR without waiting
Looking at the latest manual dated Nov 2021, there is no mention of i2c_write_slave. How do I find out what this function actually does that is different to i2c_write?
PostPosted: Thu Oct 13, 2022 2:55 pm     Reply with quote
Two ways right off:
1. In the IDE click on the Question mark in the upper right corner then choose Index and search for I2C_WRITE_SLAVE
2. In the PICC directory double click the CCSC.CHM file then select Index and search.
PostPosted: Fri Oct 14, 2022 1:36 am     Reply with quote
It is exactly the same as the I2c_write function, except it returns immediately.
The standard i2c_write, waits for the byte to be clocked out. Hence in an
ISR, when loading data that the master has requested, the old i2c_write
resulted in the ISR not exiting immediately. This one allows the ISR to
exit and the slave to get on with other things while the master reads this
byte.
As Jay says, the internal 'built in' manual does have it.
