Serial communication on 12F509
Goto page Previous  1, 2, 3  Next
PostPosted: Sat Jun 25, 2022 10:02 am     Reply with quote
How dare you use such language on the site!... Smile
nailuy
PostPosted: Sat Jun 25, 2022 1:51 pm     Reply with quote
Thank you for reply.
This is real project, test with scope for input/output for confirmation where is the hardware problem.
I use USB serial and is working in PUTTY when is RX-TX in short.
Normaly I must receive from chip 0X01 and 0X10 and infinitly 0X10.
I use FT232R chip, so pinout is correctly OKY.
But why not even simply blinking led is not working.
Also A0 where I have LED with 470R is OFF.
code is:
#include <16F1826_uart.h>
setup_adc_ports(sAN1, VSS_VDD);
setup_oscillator (OSC_8MHZ | OSC_PLL_on);
putc(0X01);  ///<<<<<<<< there is the problem/bloking the program
output_low(LED);
putc(0X10);
if(kbhit()){
   MEM_SERIAL = getc();
if (MEM_SERIAL==100){
   output_toggle(PIN_A7);
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
and
#include <16F1826.h>
#device ADC=8
#FUSES MCLR
#FUSES NOBROWNOUT
#FUSES IESO
#FUSES FCMEN
#FUSES NOWRT
#FUSES STVREN
#FUSES BORV19
#FUSES LVP
#use delay(internal=32MHz)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=PORT1)
#define LED PIN_A0
#define DELAY 1000
static unsigned int8 MEM_SERIAL;
so where is the problem?
PostPosted: Sat Jun 25, 2022 5:18 pm     Reply with quote
this ...
#FUSES LVP
change to NOLVP
as very, very few programming devices are actually 'low voltages'.
Also add 'ERRORS' to the Use rs232 (...options...),actually always add it !
and disable the comparators , pretty sure the default is 'enabled'..
Found that RX, TX are remappable using APFCONx pins ! Need to check datasheet to see what they default to be...
hmm, you Do have a pullup resistor on MCLR pin ?
It'd be a lot easier to see the whole program as ONE program. Instead of the xxxuart.h header and 'main', combine into ONE program.
PostPosted: Sat Jun 25, 2022 10:27 pm     Reply with quote
and also don't use ADC_CLOCK_INTERNAL
Doesn't matter for the serial, but on 99% of PIC's (all except some of
the very newest chips and the DSPIC's), the internal RC clock should
only be used by stopping the processor when the reading is taken.
Otherwise accuracy plummets.
nailuy
PostPosted: Sun Jun 26, 2022 1:49 am     Reply with quote
I made adjustment to program as your replied but still not working.
//setup_adc_ports(sAN1, VSS_VDD);
//setup_adc(ADC_CLOCK_INTERNAL);
setup_comparator (NC_NC_NC_NC);
BIT_SET(RXDTSEL,0); //RX to RB1
BIT_SET(TXCKSEL,0); //TX to RB2
//output_low(LED);   //<<<<< when is enabled outpus is at 0V
putc(0X01);          //<<<<< there is the problem ?!?!?
output_low(LED);
putc(0X10);
if(kbhit()){
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
and
#device ADC=8
#FUSES NOMCLR
#FUSES NOBROWNOUT
#FUSES IESO
#FUSES FCMEN
#FUSES NOWRT
#FUSES STVREN
//#FUSES BORV19
#FUSES NOLVP
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=PORT1,ERRORS)
#byte APFCON0 = getenv("SFR:APFCON0")
#bit RXDTSEL = APFCON0.7
#byte APFCON1 = getenv("SFR:APFCON1")
#bit TXCKSEL = APFCON1.0
#define LED PIN_A0
#define DELAY 1000
nailuy
PostPosted: Sun Jun 26, 2022 2:29 am     Reply with quote
oh, I changed to correct one.
BIT_clear(RXDTSEL,0); //RX to RB1
BIT_clear(TXCKSEL,0); //TX to RB2
But still not working
Also
This confirm me that CPU is working, but after this line is like blocking.
PostPosted: Sun Jun 26, 2022 4:52 am     Reply with quote
really need to do the basic '1hz LED' test.
Just have main() , toggle an LED on odd at 1Hz
use this of your code...
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
where DELAY is 500.
forget about 'serial' parts of the program.
PostPosted: Sun Jun 26, 2022 4:55 am     Reply with quote
output_low(LED); // <<<<< when is enabled output is at 0V
Do you have a series resistor for your LED ?
If you don't have a series resistor, the PIC will probably shut down when
you turn on the LED.
You could use 220 ohms.
nailuy
PostPosted: Sun Jun 26, 2022 6:02 am     Reply with quote
About of resistor, I use 470ohm.
this code is working blinking once /second.
//putc(0X01);          //<<<<< there is the problem ?!?!?
output_low(LED);
//putc(0X10);
//if(kbhit()){
//   MEM_SERIAL = getc();
//if (MEM_SERIAL==100){
//   output_toggle(PIN_A7);
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
#device ADC=8
#FUSES NOMCLR
#FUSES NOBROWNOUT
//#FUSES IESO
//#FUSES FCMEN
#FUSES NOWRT
//#FUSES STVREN
//#FUSES BORV19
#FUSES NOLVP
#define LED PIN_A0
#define DELAY 500
//static unsigned int8 MEM_SERIAL;
PostPosted: Sun Jun 26, 2022 6:54 am     Reply with quote
great so the PIC does work !
I've rearranged your code as one file, makes it a lot easier for me to read and 'flows' from the top down....silly me can't get it 'green' with code[] button.
#device ADC=8
#FUSES NOMCLR
#FUSES NOBROWNOUT
//#FUSES IESO
//#FUSES FCMEN
#FUSES NOWRT
//#FUSES STVREN
//#FUSES BORV19
#FUSES NOLVP
#define LED PIN_A0
#define DELAY 500
   output_low(LED);
       //putc(0X10);
       //if(kbhit()){
       output_low(LED);
       delay_ms(DELAY);
       output_high(LED);
       delay_ms(DELAY);
one possible problem is you have use delay set for 32MHz then later setup osc at 8MHz/pll on. I don't think you need the setup osc command.
I prefer to delete lines instead of commenting them out, again it makes it 'cleaner' to look at.
PostPosted: Sun Jun 26, 2022 7:21 am     Reply with quote
As a comment, don't use all capitals for variables.
The 'standard' in C, is to reserve ALL CAPITALS for #defines. Then used
mixed case for variables. So Mem_Serial.
The advantage of this is when looking through your program and you
see VALUE, you then 'know' that VALUE is a macro. It is a very useful
little 'immediate bit of information'.
nailuy
PostPosted: Sun Jun 26, 2022 8:24 am     Reply with quote
I clean up much as possible so now, I modify the code for easy read/understand what is happening.
output_low(LED);
delay_ms(DELAY);
output_high(LED);
delay_ms(DELAY);
and
#device ADC=8
#FUSES NOMCLR                   //Master Clear pin enabled
//#FUSES IESO                     //Internal External Switch Over mode enabled
//#FUSES FCMEN                    //Fail-safe clock monitor enabled
//#FUSES STVREN                   //Stack full/underflow will cause reset
//#FUSES BORV19                   //Brownout reset at 1.9V
#FUSES NOLVP                    //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(internal=8MHz)
#define LED PIN_A0
#define DELAY 500
why this is not working?
putc(0X01);
PostPosted: Sun Jun 26, 2022 8:55 am     Reply with quote
Almost certainly you are sending the wrong thing.
Do you really want to send the code 1?. In RS232 comms this is the code
for Start of header.
I suspect you actually want to send '1' (the ASCII code for the 'digit' 1.
So
putc('1');
Using hex this is 0x31.
nailuy
PostPosted: Sun Jun 26, 2022 8:58 am     Reply with quote
question:
If this pin TX (B2) is okay I must have 0V (or some digital oscillation 0-5V).
Why on this pin I have tristate ? voltage between 0-5V. When I put my hand I have 4V not steady value. So output is not activated for UART...
nailuy
PostPosted: Sun Jun 26, 2022 9:05 am     Reply with quote
So
putc('1');
putc(0X01); is for testing
I can change to putc(100);
Page 2 of 3
