PIC24EP512 - Read on D0 w/5.1K pull-up reads low
Goto page Previous  1, 2
PostPosted: Wed Jun 22, 2022 6:01 am     Reply with quote
yeesh Ben, this is frustrating for me...have you ANY hair left ??
Maybe toss the boards outside at noon today, supposed to be 40*C !!!
Wish I could offer a 'rabbit out of my hat' but can't think of anything as to WHY the 'odd' behaviour....
PostPosted: Wed Jun 22, 2022 9:13 am     Reply with quote
So, add BROWNOUT, and see if it makes any difference.
The point is that the erratum says the chip must have BROWNOUT enabled,
but doesn't say what happens if it isn't....
benoitstjean
PostPosted: Wed Jun 22, 2022 9:28 am     Reply with quote
Ok, that would be very strange but I will add it. I know at the moment that if a brownout occurs, when the PIC boots, it checks the restart code and pops me a message on a console so when a brownout does occur, then it will indicate that the reboot was due to a brownout.
So now the question is BROWNOUT part of the problem even though I do get the "brownout" CPU restart code?
PostPosted: Wed Jun 22, 2022 2:39 pm     Reply with quote
OK, dumb questions, looking for a rabbit for you...
Are all the PCBs from the same batch ? IE NO revisions, NO new traces, bad etches.
Does the pin actually work as an output normally ? correct voltages ?
Any other 'peripheral' magically attached to it by 'default' ?
benoitstjean
PostPosted: Thu Jun 23, 2022 5:50 am     Reply with quote
Yep, same PCB batch, I haven't tested the pin as an output yet but given it doesn't cause me too much grief other than the fact I don't understand what is going-on, I found a way through the code to bypass this problem.
Thanks.
Ben
Page 2 of 2
