warnings in the stdlib.h
gsilvis
PostPosted: Wed Mar 03, 2004 9:28 am     Reply with quote
There are numerous warnings from the stdlib.h:
Warning 201 "C:\PROGRA~1\PICC\drivers\stdlib.h" Line 307(1,1): Assignment inside relational expresion -1 is not 0..255
Is this normal? Should I just turn off the warnings or ignore them?
George
PostPosted: Wed Mar 03, 2004 12:51 pm     Reply with quote
Since we don't know exactly which stdlib.h file you have,
(ie., they may change between different versions)
can you post the line of code in stdlib.h that is causing
the problem ? Also post the name of the routine in
stdlib.h that contains that line ?
