strcmp strange length limitation [Solved]
FFT
PostPosted: Sun Jan 09, 2022 11:52 am     Reply with quote
The following statement is true TEST_VAL's char length is 4 or less
if(strcmp((char *)TEST_VAL, (char *)&Buffer[1]) == 0)
true when:
#define TEST_VAL    "1234"
false when:
#define TEST_VAL    "123412341234123412341234"
Obviously Buffer[1] is start of the same string compared with the TEST_VAL.
I also tried using
#device PASS_STRINGS = IN_RAM
but nothing changed.
Buffer is defined as:
unsigned int8 Buffer[64];
and filled by serial communication.
I also tried with a custom implementation of the strcmp, result is the same.
Is this something special to CCS?
PostPosted: Sun Jan 09, 2022 12:29 pm     Reply with quote
This works:
#include <18F46K22.h>
#fuses NOWDT
#use delay(internal=4M)
#use rs232(UART1, baud=9600, ERRORS)
#include <string.h>
unsigned int8 Test_val[64] =  "123412341234123412341234";
unsigned int8 Buffer[64] =  "123412341234123412341234";
if(strcmp(test_val, Buffer) == 0)
   printf("Matched\r");
   printf("No match\r");
while(TRUE);
I see two problems in your posted code.
Below, you are trying to create a pointer to a constant.
The compiler will give you an error. It will not compile.
Below, you apparently think a string starts at index 1.
But it actually starts at index 0.
FFT
PostPosted: Sun Jan 09, 2022 2:15 pm     Reply with quote
Thanks! This fixed my issue, v5.104 did not give an error for this. I just used a RAM variable and issue has fixed.
PostPosted: Mon Jan 10, 2022 1:25 am     Reply with quote
You can use the #defined version with this:
#device PASS_STRINGS=IN_RAM
#fuses NOWDT
#define Test_val  "123412341234123412341234"
#include <string.h>
   while(TRUE);
The specific things. First understand what PCM has told you about where strings 'start'. The first byte is [0], not [1]. Then note the second line
in the code I posted. This tells the compiler to 'virtualise' constant strings
into RAM when needed.
