18F2550 I2c Software
vtrx
PostPosted: Tue Sep 14, 2021 4:50 pm     Reply with quote
I need to use a 24C08 memory with the 18F2550, but using software routines.
I use native SPI for another circuit.
Using the described methods, I can't get results in the simulation.
Is the described procedure correct?
#use I2C(sda=PIN_A1, scl=PIN_A0, FAST=100000)
void ext_24c08_write(unsigned int8 address,data)
  i2c_start();
  i2c_write(WRITE_ADDR);
  i2c_write(address);
  i2c_write(data);
  i2c_stop();
int8 ext_24c08_read(unsigned int8 address)
int8 result;
   i2c_start();
   i2c_write(address);
   i2c_start();
   i2c_write(READ_ADDR);
   result = i2c_read(1);
   i2c_stop();
   return(result);
PostPosted: Tue Sep 14, 2021 5:59 pm     Reply with quote
simulation' ?
What are you using as a 'simulator' ??
vtrx
PostPosted: Tue Sep 14, 2021 7:31 pm     Reply with quote
Before losing more hair, I simulated with Proteus.
Are the codes correct?
PostPosted: Tue Sep 14, 2021 7:47 pm     Reply with quote
sorry, but I don't use Proteus. It's well know to not work 100% as a PIC simulator.
PostPosted: Tue Sep 14, 2021 8:04 pm     Reply with quote
Why don't you use the 2408.c file provided by CCS in the Drivers folder ?
It's significantly different than what you posted. You should try it.
vtrx
PostPosted: Wed Sep 15, 2021 9:08 am     Reply with quote
Thanks.
I'm going to use this method, anyway the problem was in emulation.
Every time I want to use a communication, which the microcontroller has implemented by hardware, and I want to use it by software, I just need to choose non-standard pins?
PostPosted: Wed Sep 15, 2021 9:14 am     Reply with quote
You can also use the FORCE_SW switch under I2C.
See the #use I2C section in the manual
PostPosted: Wed Sep 15, 2021 9:24 am     Reply with quote
Honestly I'd suspect the 'simulation'. It probably cannot actually handle
interpreting software I2C.
The reason the standard driver is different, is that the address for the
2408, is actually a 10bit value, and the extra 2 bits have to be masked
into the device address sent. However omitting these (provided your
value for WRITE_ADDR, and READ_ADDR, have sensible settings for these,
that match), should not matter.
PostPosted: Wed Sep 15, 2021 9:55 am     Reply with quote
int8 result;
i2c_start();
i2c_write(address);
i2c_start();
i2c_stop();
return(result);
Also, your code above is incorrect. The last i2c_read() should have
a parameter of 0. Look at the CCS code. They have a 0. This is part
of the i2c spec.
vtrx
PostPosted: Wed Sep 15, 2021 3:00 pm     Reply with quote
I'm using 2408.c (write_ext_eeprom(x,x)/read_ext_eeprom(x)).
PostPosted: Thu Sep 16, 2021 3:53 am     Reply with quote
PCM is pointing out why your original code would not work.
Learn from him for any future code you write.
