convert char to integer?
erpgc82
PostPosted: Mon Aug 23, 2021 8:21 am     Reply with quote
Hi, how do I convert characters to integers?
I'm getting serial numbers like: 1, 2, 3, 4, 5, 6.
But an example the 2 and the 3, I get 50 and 51.
I tried
value = (int) receive[x];
value = toint (receive[x]; // this function no longer exists in CCS.
value = atoi(receive[x]); // this function no longer exists in CCS.
in another situation I did as below, and it worked:
if (x=='1') value = 1;
if (x=='2') value = 2;
and so on, it works, but it gets too long!
Gradually you will go far with persistence, will and determination!
PostPosted: Mon Aug 23, 2021 8:30 am     Reply with quote
toint is in the forum archives. Click the search link above and
type in toint and click the Search button. It's in the 2nd hit.
erpgc82
PostPosted: Mon Aug 23, 2021 10:16 am     Reply with quote
Ok thank you PCM Programmer!
It worked, my problem is solved, really easy.
but the question is, what does this definition do?
#define toint(c) ((int)((c)-'0')) Laughing
create a definition called toint ok
((c)-'0') Confused
I didn't understand, I'm new to C CCS PIC, I've been programming for 1 year, I still consider myself an apprentice
PostPosted: Mon Aug 23, 2021 10:33 am     Reply with quote
It removes the ASCII bias, leaving just the integer.
Look at an ASCII table on the internet. Notice that '0' (zero)
has the ASCII value of 0x30. '1' is 0x31, 2 is 0x32, etc,
If you subtract 0x30 from each of those, you get just the
integer value: 0, 1, 2, etc.
PostPosted: Mon Aug 23, 2021 12:47 pm     Reply with quote
The key point, is whether you want to convert a whole sequence of
characters or just one.
The definition just converts the ASCII value for a numeric character to
it's numeric value.
If you study it, '0', gives the numeric ASCII value of the character 0.
If you run 'charmap' in Windows, and select the '0' character it tells you
this is ASCII 0x30. Also looking at the characters there the numeric
characters are sequential, so the maths in atoi, gives a numeric value of
zero for '0', and one for '1'' etc..
atoi, converts a whole string 'sequence' of characters into it's numeric
value.
So if you are receiving multiple characters, look at atoi. For the
single character use the definition...
