O.T. - WDT timeout
Doug
O.T. - WDT timeout
PostPosted: Mon Mar 01, 2004 11:13 am     Reply with quote
Where in the program should I put restart_wdt()? I need the prescaler for timer0 and my program loop is 35ms. Would it be a bad idea to put a restart_wdt() instruction inside a delay loop which lasts 25ms? If the program gets stuck in the loop it will never time out. What should I do?
Thanks,
Doug
agrj
PostPosted: Mon Mar 01, 2004 11:27 am     Reply with quote
which PIC are you using? how are you doing this loop?
thanks
Dinho
Re: O.T. - WDT timeout
PostPosted: Mon Mar 01, 2004 11:53 am     Reply with quote
Thanks,
Doug
You speak as though you are waiting for an 'event', that happens at 35mSec intervals?.
If so, then consider using a counter inside your wait loop. Something like:
counter=65000;
while (TRUE) {
    if (counter) {
       --counter;
       restart_wdt();
    if (check_for_event()) break;
//The code will arrive here, if the 'check_for_event' test has returned true
If the counter gets to zero before the 'check_for_event' test returns true, the watchdog will stop resetting, and 18mSec latter the watchdog will trigger. The 'event' is still tested in this time.
Doug
PostPosted: Mon Mar 01, 2004 12:39 pm     Reply with quote
I'm using a 12c672 (I would like to use a 12F675 but my compiler version does not do them.)
Here is the loop:
no_pulse = TRUE;                      // set no_pulse flag
time_out = MAX_OFF_TIME;            // number of times to loop
do{
   if (!input(PULSE_IN)) {          // test PULSE_IN pin
      disable_interrupts(GLOBAL);
      edge_detect();           // call routine to measure pulse
      if (!no_pulse)             // if no_pulse is cleared,
         break;                  // jump out of loop
} while(--time_out);
It loops the number of times in time_out and if PULSE_IN pin goes low it calls edge_detect() which will measure the length of the pulse and make no_pulse FALSE. When time_out reaches 0 it will exit the loop with no_pulse set to TRUE.
Thanks,
Doug
Doug
PostPosted: Mon Mar 01, 2004 12:45 pm     Reply with quote
Can just I add a restart_wdt() into the loop? or is it better to have it outside the loop.
How many of you actually use the WDT?
Thanks,
Doug
automatic Delay Watchdog restart
PostPosted: Mon Mar 01, 2004 1:20 pm     Reply with quote
You might read the user manual about #use delay(xxxxxxx, restart_wdt) to see if this might help.
PostPosted: Mon Mar 01, 2004 1:36 pm     Reply with quote
There are lots of articles on how to use a watchdog timer
over at Embedded.com. Here is one:
http://www.embedded.com/story/OEG20010920S0064
Doug
PostPosted: Mon Mar 01, 2004 2:58 pm     Reply with quote
Thank you, that cleared up a few questions.
Doug
