restart_cause() returning 16 (not defined in 24FJ256GA106.h)
allenhuffman
PostPosted: Thu Aug 19, 2021 11:25 am     Reply with quote
// Constants passed into RESTART_CAUSE() are:
#define RESTART_POWER_UP      0
#define RESTART_BROWNOUT      1
#define RESTART_WATCHDOG      4
#define RESTART_SOFTWARE      6
#define RESTART_MCLR          7
#define RESTART_ILLEGAL_OP    14
#define RESTART_TRAP_CONFLICT 15
Anyone know what restart cause 16 is? It is not listed in the PIC24 header file.
Thanks...
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Thu Aug 19, 2021 1:56 pm     Reply with quote
Don't know but I'd be reading the datasheet of the PIC..mind you after the first 500-600 pages my mind would be a tad blurry....
allenhuffman
PostPosted: Thu Aug 19, 2021 2:38 pm     Reply with quote
The data sheet gives them as bits, and it looks like the CCS call is returning the bit number. Convenient.
RESTART_POWER_UP      0 -- bit 0 (POR)
RESTART_BROWNOUT      1 -- bit 1 (BOW)
RESTART_WATCHDOG      4 -- bit 4 (WDTO)
RESTART_SOFTWARE      6 -- bit 6 (SWR/RESET)
RESTART_MCLR          7 -- bit 7 (MCLR)
RESTART_ILLEGAL_OP    14 -- bit 14 (IOPUWR)
RESTART_TRAP_CONFLICT 15 -- bit 15 (TRAPR)
16 is, therefore, invalid.
Dunno!
PostPosted: Fri Aug 20, 2021 12:17 am     Reply with quote
The CCS code, scans through the set bits, and returns the number of the bit
it sees. It loads a '1' into the top bit of the register at the start of the
rotation. So if _no restart cause_ is seen, it will return 16 (on the DSPIC's).
The point is that getting 16, implies the code has jumped to the test,
without setting any restart bit.
So if (for instance), you coded as:
   int cause;
       cause=restart_cause();
       printf("Case was &d", cause);
   } //and loop back to the test
You will get the expected cause (probably 0 the first time), and then
a sequence of 16's.
So 16, is actually 'a restart has not occurred'.
allenhuffman
PostPosted: Fri Aug 20, 2021 7:01 am     Reply with quote
a sequence of 16's.
That is interesting. I only run that code at the top of my main(). I wonder what else could make my main() restart.
PostPosted: Fri Aug 20, 2021 8:15 am     Reply with quote
The obvious thing would be something like a return instruction, when a
zero value has been pushed onto the stack.
You can jump to any location in memory, or return to any location.
Provided the stack doesn't underflow you can go anywhere.....
allenhuffman
PostPosted: Fri Aug 20, 2021 8:34 am     Reply with quote
Ah, a 0 is the GOTO vector. I’ll keep an eye out.
PostPosted: Fri Aug 20, 2021 9:47 am     Reply with quote
Have a global variable declared that is not initialised.
Then in your restart_cause test code, if it is a restart from power up, set
this to zero.
Then through you code at different points, set it to different values.
When you get the 16, see what is in this variable. It'll tell you where the
code got to, which can narrow down where the problem is.
