raman00084@gmail.com
| converting hexadecimal to decimal value |
Posted: Sat Jul 24, 2021 1:55 am |
char gps_buf[]={"GPGGA,000044.262,,,,,0,0,,,M,,M,,*4E"};
in the array the last 2 characters is the check sum value ( 4E)
HOW CAN I CONVERT THE LAST 2 CHARACTERS TO DECIMAL VALUE
FOR EXAMPLE
CHAR CHECK_SUM[3]={0}
CHECK_SUM[0]='4';
CHECK_SUM[1]='E';
HOW TO CONVERT THIS TO DECIMAL VALUE THAT IS 78
KINDLY HELP. |
Posted: Sat Jul 24, 2021 4:39 am |
quick reply..
CCS supplies the function ATOI().
If you open the manual, it's listed and the example program 'input.c' shows how to use it.
jay |
Posted: Sat Jul 24, 2021 10:45 am |
Though atoi is supplied, it is quite a complex way of doing the conversion.
Easier to just use a simple convert and multiply on the characters. So:
int htodec(char c)
if(c >= '0' && c<= '9')
return c-'0';
if(c >= 'A' && c <= 'F')
return c-55;
if (c >= 'a' && c <= 'f')
return c-87;
return 0; //Impossible character
//then for the locations of the '4E':
val=htodec(gps_buf[34])*16+htodec(gps_buf[35]);
Should give the value in decimal.
I think I've counted the locations correctly (do check...).
This is faster and smaller than using atoi |
Posted: Sun Jul 25, 2021 5:13 am |
Hey Mr. T....
Using Notepad+, I get 35, and 36 as the locations.
BUT...that's really 34 and 35 as we have to start at ZERO for arrays.
In QB45 you could use either '0' or '1' as the starting cell.
Posted: Sun Jul 25, 2021 6:57 am |
Cor, I counted right!...
I was just counting characters on a laptop. |
