How to use #use pwm()
dmitrboristuk
PostPosted: Thu Jun 24, 2021 1:32 am     Reply with quote
How to use #use pwm() on devices with multiple independent PWMs ?
For example: is it possible to apply this directive for separate control of PWM1, PWM2, PWM3, PWM4 ? And if so, then how exactly to do it for BIF pwm_off() and pwm_on() ?
PostPosted: Thu Jun 24, 2021 2:15 am     Reply with quote
Using multiple #use pwm statements is shown here:
http://www.ccsinfo.com/forum/viewtopic.php?t=59193&highlight=pwm
Each pwm, needs a specific stream name, and this can then be given
to the off/on functions.
dmitrboristuk
PostPosted: Thu Jun 24, 2021 3:20 am     Reply with quote
#use delay ( clock = 16000000 )
#USE PWM(CCP1, OUTPUT=PIN_C1, TIMER=2, FREQUENCY=10kHz, DUTY=50, PWM_OFF, STREAM=1)
#USE PWM(PWM3, OUTPUT=PIN_C2, TIMER=4, FREQUENCY=5kHz, DUTY=25, PWM_OFF, STREAM=2)
#USE PWM(PWM4, OUTPUT=PIN_C3, TIMER=6, FREQUENCY=3.33kHz, DUTY=16.6, PWM_OFF, STREAM=3)
// for example
   pwm_on (1);
   pwm_on (2);
   pwm_off (3);
   delay_ms (20);
   pwm_off (1);
   pwm_off (2);
   pwm_on (3);
is it right?
PostPosted: Thu Jun 24, 2021 3:55 am     Reply with quote
Stream names, need to be unique names, not just numbers.
Without knowing what chip you are using, can't know if it supports
the pins and timers you are specifying.
