colin382
Pickit4 not recognised |
Posted: Wed Jun 16, 2021 10:59 am |
I use the Workshop compiler and a Pickit4 for programming. When I came back to C and the CCS compiler after a time away, I plugged in the Pickit4 and it just worked, no problem.
When a problem cropped up and the programmer failed to program. I concluded the programmer was at fault and bought another Pickit4. However, with this one the compiler firstly wants to know how it is connected (USB) then complains that there is another program already connected to the programmer (there isn't), and I have to exit the program and click retry. So basically useless at present.
In the "more details panel" I read:
Software version 5.068
v5.68 of C:\Program Files\(x86)PICCW\dll\CCSICD.dll
v5.68 of C:\Program Files\(x86)PICCW\dll\CCSICDU.dll
INF File *
Active Debugger: ICD-USB: 5.068
Debugger DLL: ccsicdu
I'm using PICCW, version 5.094 with a PIC18LF24K22.
The new Pickit4 is serial BUR210574366.
My problem now seems to be with my prototype hardware, the old PicKit4 works with an earlier very similar design on the same chip. So this post is an attempt to get some value from the second programmer. |
colin382
Posted: Thu Jun 17, 2021 7:50 am |
Thanks for your interest in this problem.
I read the link you provided, but it doesn't really match my problem.
The LED does light, neither the good or bad Pickit4s show in Device Manager and I would rather not get involved with MPLAB X.
Also, the new device is brand new yesterday, so should already be at default.
The good news is that I have the original Pickit4 working again- there was a flaky connection at PGD on the prototype.
In case anybody else reads this, I made two errors in the original post: I am using compiler version 5.94, and the chip is a 18LF25K22. |
Posted: Thu Jun 17, 2021 7:54 am |
colin382 wrote: |
There is no CCS vs. 5.94. The highest version is 5.104.
But there is a vs. 5.094. See the CCS versions page:
http://www.ccsinfo.com/devices.php?page=versioninfo |
asmallri
Joined: 12 Aug 2004 Posts: 1646 Location: Perth, Australia
Posted: Fri Jun 18, 2021 8:24 am |
colin382 wrote: |
I sniggered when I read that based on my own experience. I found myself in the similar position, although with a SNAP programmer as opposed to a PICKIT4 and I did recover this brand new, straight out of the box, device by resetting.
You might also want to check your schematic to ensure it conforms to the ICSP recommendations from Microchip and check the physical hardware to ensure the resistors are the correct value and are in fact actually electrically sound. I previously had a related problem programming a PIC via ISCP and it turned out to be a faulty SMD resistor. Perfected solder but open circuit. _________________ Regards, Andrew
