radi Guest
comments in macro |
Posted: Thu Feb 26, 2004 3:59 am |
Do someone knows how may I put comments inside micro?
I try something like this:
#define display()\ //Macro for....
output_b(0b11111111);\ // Mask PORTB.
output_high(PIN_A5);\ // set "a" segment.
delay_cycles(80);\ //.......
PORTA=(PORTA&0b11111000)|temp0_interrupt; // Select current display.
When I clear the comments everything is allright, but when I have comments the problems come. |
Re: comments in macro |
Posted: Thu Feb 26, 2004 5:31 am |
radi wrote: | Do someone knows how may I put comments inside micro?
You should put the comments before the '\'.
Do them like this:
#define display() /*Macro for...*/\
output_b(0b11111111); /* Mask PORTB.*/\
output_high(PIN_A5); /* set "a" segment.*/\
delay_cycles(80); /*.......*/\
PORTA=(PORTA&0b11111000)|temp0_interrupt /* Select current display.*/
Note also that you don't really want the ';' at the end of the last line (since presumably 'display', will be typed as 'display();', and you will get an 'extra' ';', when the expression is expanded.
The problem is that the '\', means 'skip the significance of the following line feed', and the compiler does not 'remember' this to the end of the line if followed by a comment. Using '/* */', allows you to terminate the comment, and then use the '\'.
RADI
RADI |
Posted: Fri Feb 27, 2004 3:16 am |
Ttelman, thank you very much! Now everything is clear for me.
