Problem with DS3231 and PIC16F1847
Goto page Previous  1, 2, 3, 4  Next
jake1272
PostPosted: Sun Apr 11, 2021 12:38 pm     Reply with quote
Yes, I have done that as well. Sad I even replaced the DS3231 still
PostPosted: Sun Apr 11, 2021 3:01 pm     Reply with quote
I don't see that CCS has a ds3231.c driver file.
I have vs. 5.103 installed and these are all the files starting with "ds":
06/23/2003 03:45 PM 1,928 ds1868.c
06/23/2003 03:48 PM 2,862 ds1624.c
06/23/2003 03:49 PM 4,149 ds1621m.c
06/23/2003 03:49 PM 3,613 ds1621.c
08/06/2004 02:09 PM 50,555 ds2432.c
08/17/2005 11:00 AM 3,055 ds1631mm.c
03/02/2010 02:35 PM 20,648 ds1993.c
08/06/2013 09:39 AM 4,909 ds1302.c
08/06/2013 09:42 AM 5,107 ds1338.c
12/22/2014 03:02 PM 9,768 ds1305.c
08/12/2016 02:01 PM 25,548 dsp_data_util.c
09/16/2016 08:04 AM 8,068 ds18b20.c
04/22/2019 01:49 PM 2,723 ds1631.c
11/04/2020 02:13 PM 37,893 ds18B20_multidrop.c
I don't think you got the driver from CCS.
Post a link to the website where you got the driver, so we can look at it.
PostPosted: Sun Apr 11, 2021 4:31 pm     Reply with quote
Found it !!!! well, I think so....
https://simple-circuit.com/ds3231-rtc-driver-ccs-c-compiler/
He had the driver in the original post, but removed it, as moderator thought it was an official CCS product.....
Jay
dyeatman
PostPosted: Sun Apr 11, 2021 4:42 pm     Reply with quote
Actually that was me.
It appeared to have the CCS Header and it was in the CCS driver directory in
the example so I alerted him about it.
I do'nt see it in my listing either.
Google and Forum Search are some of your best tools
PostPosted: Sun Apr 11, 2021 10:48 pm     Reply with quote
What are your connections to the Vbat and RST pins on the ds3231 ?
What is the voltage on the Vcc pin of the ds3231 ?
What is the PIC's Vdd voltage ?
jake1272
PostPosted: Mon Apr 12, 2021 12:32 am     Reply with quote
Jay
Yes I got the driver from that website you have mentioned
jake1272
PostPosted: Mon Apr 12, 2021 12:43 am     Reply with quote
PIC's Vdd voltage = 5V
Vcc pin on DS3231 =5V
For Vbat and RST I don't have those pins .I only have vcc, sda,scl ,sqw,32k, and ground
I Use PIN_A0 for SDA
I Use PIN_A1 for SCL
PostPosted: Mon Apr 12, 2021 12:55 am     Reply with quote
I think you mean that you're using a module with a battery installed on
the back side of the board.
Is there a battery installed ? Can you measure the voltage of it ?
PostPosted: Mon Apr 12, 2021 12:59 am     Reply with quote
Are you using some sort of board with the chip?. If so, does this have a battery
on it?. If so, this is the 'Vbat'.
The chip will not keep time when switched off, without a battery. If this pin
is not used, it needs to be connected to the 0v. You can't just not connect it.
Post what board you are using?. A link to the site where it has come from?.
Just as for this pin, all the 'NC' pins on the chip _must_ be connected to
0v.
Now you can run with Vcc connected to the Vbat pin. If this is done, the Vcc
pin needs to connect to 0v, and there must be a decoupling capacitor on the
Vbat pin.
These 'details' are what affects how the unit will work.
PostPosted: Mon Apr 12, 2021 1:01 am     Reply with quote
I looked at the simple circuits page that has CCS code for the ds3231.
It shows the following main() function. Notice that he initializes the RTC
chip with the date and time. You cut that out.
Why not just copy his code exactly ?
  delay_ms(1000);  // wait a second
  lcd_init();
  lcd_putc('\f');
  // read current time and date from the RTC chip
  mytime = RTC_Get();
  // print them
  rtc_print();
  // set RTC time to 21:08:47 (hh:mm:ss) and date to 03-01-19 (dd-mm-yy)
  mytime->hours   = 21;
  mytime->minutes = 8;
  mytime->seconds = 47;
  mytime->dow     = THURSDAY;
  mytime->day     = 3;
  mytime->month   = JANUARY;
  mytime->year    = 19;
  // write time and date to the RTC chip
  RTC_Set(mytime);
  // enable SQW output with frequency of 1Hz
  IntSqw_Set(OUT_1Hz);
    mytime = RTC_Get();
    // read chip temperature
    chip_temp = Get_Temperature();
    // print all data
    rtc_print();
    delay_ms(100);  // wait 100 ms
jake1272
Yes there is a battery installed on the back with 3.6V
jake1272
PostPosted: Mon Apr 12, 2021 1:44 am     Reply with quote
Similar DS3231:https://www.digitspace.com/ds3231-rtc-module-real-time-clock-module-at24c32-high-accuracy
Jerson
PostPosted: Mon Apr 12, 2021 4:24 am     Reply with quote
To begin with debugging your code, I would
* comment all calls to the RTC driver functions.
* Replace the print statement with dummy values for each variable you print
* If you succeed with this, then re-enable RTC_get and check if it prints some values
Unless this works, do not check other RTC functions.
PostPosted: Mon Apr 12, 2021 5:05 am     Reply with quote
a comment...
I do the lcd_init() THEN the delay_ms(1000).
This ensures the LCD module has more than enough time to do it's 'setup'.
Depending on who wrote the LCD driver, there may or may not be a long enough delay for the LCD module being used.
It also allows external peripherals time to properly 'powerup'.
PostPosted: Mon Apr 12, 2021 7:19 am     Reply with quote
Actually, delaying first is more normally what is needed....
Problem is that the standard Hitachi LCD controller carefully specifies that
it can accept commands just 15mSec after the supply comes on. However
a lot of the 'clone' LCD's need longer, and also many of the LCD's don't
actually 'start' this time, till the supply has risen further than the PIC needs
to start.
I suspect you use PCM Programmer's flex LCD driver. this allows 35mSec
for the display boot, so normally works. However the poster here is using the
CCS driver, and this often has problems unless a little extra time is allowed
before lcd_init is called.
Page 2 of 4
