CCS C Compiler 5.090 Enable warnings in MPLAB X IDE
Marco27293
PostPosted: Tue Dec 15, 2020 3:02 am     Reply with quote
Usually when I build and clean the main project in MPLAB IDE, I see warnings in the output window.
They are actually 0 though the code is the same which gave a lot of warnings yesterday.
Maybe, I've erroneously switched-off warning reports. How can I re-enable them?
Regards,
Marco
PostPosted: Tue Dec 15, 2020 7:06 am     Reply with quote
Unless you have edited the command line that MPLAB uses to call the compiler,
this should not change. Remember there is always the .err file you can
look at.
Marco27293
PostPosted: Tue Dec 15, 2020 7:13 am     Reply with quote
In .err file I get 0 warnings.
How can I fix?
PostPosted: Tue Dec 15, 2020 7:29 am     Reply with quote
Right click on your project. Select 'properties'. In the left window
select 'compiler options'. Right hand window, second line down, select
'Show all errors, All warnings'. Select 'apply', and 'OK'.
