PIC24FJ64GA004 - detecting I2C stop bit (P) inside an ISR
Goto page Previous  1, 2, 3
allenhuffman
PostPosted: Fri Dec 04, 2020 12:04 pm     Reply with quote
Ttelmah wrote:
Er. Level=7, is the highest priority. Not what is wanted.....
Level=1.
I haven’t even looked at that yet. I just assumed "there must be a reason it says 7" Smile
We use a ton of timers (most use every timer available) and I2C as the only interrupts.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
allenhuffman
PostPosted: Wed Dec 16, 2020 11:16 am     Reply with quote
Just curious... I based my polled I2C routines on existing examples. As such, after each byte, I poll looking for either a stop bit or the next incoming ISR flag:
        // Wait for either a stop bit, or another incoming data byte.
        while ((P == 0) && (I2C_SYSTEM_BUS_IRQ_PENDING_BIT == 0));
        if (P != 0)
            //DEBUG_PRINTF ("P");
I recently saw code that polled the RBF (receive buffer full) status instead of the IRQ pending bit.
Is there an advantage to one method over the other? I just tested the RBF method in my code and it seems to also work fine... Block until there is either another byte to read, or a stop bit has been seen.
PostPosted: Thu Dec 17, 2020 1:22 am     Reply with quote
Some chips have errata on one. On these it is recommended to use RBF
rather than the interrupt. Also, though your chip doesn't support interrupt
on start/stop, a lot do. On these if you checked the interrupt, it might be
one of these, not the data....
Page 3 of 3
