hamid9543
| I2c search problem |
Posted: Fri Oct 30, 2020 11:19 am |
hi,
When i run i2c search() in dspic, dspic hang up.
But if i reset slave via mclr, master will find slave device and hang up again!!!
master:
dspic33ep128gp506
ccs 5.093
#include <33EP128GP506.h>
#device ICSP=1
#include <ConfigureClock.h>
#pin_select U1TX = PIN_F1
#pin_select U1rX = PIN_F0
#use rs232(UART1, baud=9600,xmit=pin_f1,rcv=pin_f0)
#use i2c(MASTER,I2C1,Force_HW,slow)
unsigned int8 status;
unsigned int8 get_ack_status(unsigned int8 address)
i2c_start();
status = i2c_write(address);
i2c_stop();
if(status==0) return(TRUE);
else return(FALSE);
void Search_i2c()
printf("\n\rStart:\n\r");
delay_ms(200);
unsigned int8 count = 0;
for(unsigned int8 i=0x10; i < 0xF0; i+=2)
status = get_ack_status(i);
if(status == TRUE)
printf("Addr:%X\n\r",i);
count++;
// delay_ms(100);
if(count == 0) printf("Nothing Found\n\r");
else printf("Chips Found=%u\n\r",count);
setup_pll();
printf("Test\r\n");delay_ms(50);
while(True)
Search_i2c();
Slave:
pic16f1829
#include <16f1829.h>
#FUSES NOWDT//,NOPUT,NOBROWNOUT,NOMCLR,INTRC_IO
#use delay(internal=32Mhz)
#use i2c(Slave,sda=PIN_B5,scl=PIN_B7,address=0x40,force_hw)
//#use i2c(Slave,I2C2,address=0x40,force_hw)
unsigned int8 data[2];
#INT_SSP
void SSP_isr(void)
int8 state = i2c_isr_state();
if(state < 0x80) // Master is sending data
i2c_read();
if(state >= 0x80) // Master is requesting data from slave
i2c_write(data[state-0x80]);
enable_interrupts(INT_SSP);
while(TRUE){output_high(pin_b6);}
Posted: Fri Oct 30, 2020 2:18 pm |
hmmm
1) what does '#include <ConfigureClock.h> ' contain ??
2) have you run PCMP's I2C Scanner program from the Code Library ?
3) what value I2C pullups are you using ??
4) what is VDD of both PICs ? |
Posted: Sat Oct 31, 2020 1:15 am |
There is a huge issue with what is posted. The second I2C slave setup line
'remmed out', is actually the correct line to setup I2C2 which is what is needed
for the pins involved. Then however the interrupt will not be INT_SSP,
but INT_SSP2.
So the slave needs:
//#use i2c(Slave,sda=PIN_B5,scl=PIN_B7,address=0x40,force_hw)
//This actually sets up I2C2, but does not say so amywhere
#use i2c(Slave,I2C2,address=0x40,force_hw, STREAM=PORT2)
//This physically reminds us this uses I2C2
//So we now know we have to use INT_SSP2
#INT_SSP2
void SSP2_isr(void)
int8 state = i2c_isr_state(PORT2);
i2c_read(PORT2);
i2c_write(PORT2, data[state-0x80]);
enable_interrupts(INT_SSP2);
Currently what is happening the SSP2 hardware is triggering, but there
is no handling software for this, so the SCL line gets held low, hanging
the I2C bus. The master then sits waiting for the bus to release.
Resetting the slave releases this.
When working with devices with multiple hardware, you must always
make sure that you are handling the right hardware. Any 'keys' you
can use (like specifying UART2, or I2C2), are helpful reminders of
which hardware is involved. |
hamid9543
Posted: Sat Oct 31, 2020 9:54 am |
| temtronic wrote: | hmmm
what is PCMP's I2C Scanner program? |
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Sat Oct 31, 2020 10:30 am |
| hamid9543 wrote: |
It's free code in the library here from PCM Programmer (I didn't look - but I'm guessing that who Ttelmah is talking about)
Go look in the code library of this forum for "I2C Scanner"
Cheers,
hamid9543
Posted: Sat Oct 31, 2020 10:35 am |
| Ttelmah wrote: | There is a huge issue with what is posted. The second I2C slave setup line
but INT_SSP2.
So the slave needs:
#INT_SSP2
void SSP2_isr(void)
i2c_read(PORT2);
Thx. solved for slave pic16f1829. but when slave is pic18f46k22 master not found slave
#include <18F46K22.h>
#FUSES NOWDT,NOBROWNOUT,NOPUT,PLLEN,INTRC_IO
#device ADC=8
//#use delay(internal=64mhz)
#use delay(clock=64000000)
#define b_high output_high(PIN_c0)
#define b_low output_low(PIN_c0)
#define l_high output_high(PIN_a4)
#define l_low output_low(PIN_a4)
#define r_high output_high(PIN_a6)
#define r_low output_low(PIN_a6)
#define f_high output_high(PIN_a7)
#define f_low output_low(PIN_a7)
#define b_toggle output_toggle(PIN_c0)
#define l_toggle output_toggle(PIN_a4)
#define r_toggle output_toggle(PIN_a6)
#define f_toggle output_toggle(PIN_a7)
#define I2C_INT pin_C1 //D2
#define cal_key !input(pin_e2)
//#use i2c(SLAVE,SCL=PIN_C3,SDA=PIN_C4,address=0xA0,FORCE_SW)
#use i2c(SLAVE,I2C1,address=0xA0,FORCE_SW,STREAM=PORT1)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=pin_a4,bits=8,stream=blt)//bluetooth terminal//password:1234
#INT_SSP
void ssp1_interrupt()
int state = i2c_isr_state();
i2c_read();
setup_oscillator(OSC_64MHZ, OSC_PLL_ON);
/* output_low(I2C_INT);
set_analog_pins(PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A5,
PIN_B0,PIN_B1,PIN_B2,PIN_B3,PIN_B4,
PIN_B5,PIN_C5,PIN_C7,PIN_D0,PIN_D1,
PIN_D2,PIN_D3,PIN_D4,PIN_D5,PIN_D6);
setup_adc(ADC_CLOCK_DIV_8|ADC_TAD_MUL_0);*/
while(True)
for(int j=0;j<3;j++){
f_high;delay_ms(60);l_high;delay_ms(60);b_high;delay_ms(60);r_high;delay_ms(60);
f_low; delay_ms(60);l_low; delay_ms(60);b_low; delay_ms(60);r_low; delay_ms(60);}
b_low; f_low; l_low; r_low;
Posted: Sat Oct 31, 2020 11:06 am |
this..
...may be the problem...
You're telling the compiler to use software for the I2C transactions and NOT the internal MSSP peripheral. By doing this you probably do NOT have I2C interrupt ability.
others will know for sure |
Posted: Sat Oct 31, 2020 11:27 am |
You cannot use software for a slave. Look at the manual. No, it
will not work.
| Quote: |
CCS offers support for the hardware-based I2CTM and a software-based master I2CTM
The software I2C implementation is for _master only_.
and obviously, software I2C 100% guarantees no interrupt ability, |
hamid9543
Posted: Sat Oct 31, 2020 1:02 pm |
| Ttelmah wrote: | You cannot use software for a slave. Look at the manual. No, it
will not work.
| Quote: |
how config i2c?
#use i2c(SLAVE,I2C1,address=0x42,FORCE_HW,STREAM=PORT1)
Posted: Sat Oct 31, 2020 1:17 pm |
Also, this stuff doesn't work:
| Quote: | set_analog_pins(PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A5,
PIN_D2,PIN_D3,PIN_D4,PIN_D5,PIN_D6); |
Look in the .h file for your PIC, and look in the section for:
| Quote: | | set_analog_pins( ) |
and it will show you the parameters that it accepts. |
hamid9543
Posted: Sat Oct 31, 2020 1:26 pm |
| PCM programmer wrote: | Also, this stuff doesn't work:
working properly!! |
