Reading AD channels data to detect sensor errors
colesha
PostPosted: Thu Oct 08, 2020 4:50 am     Reply with quote
i am trying to write a code that can frequently read each analog input and use it to detect an input error or a sensor failure.
Below is the code for scanning the analog inputs
void get_analog_data (void)
   analog_data[a2d_chan] = read_adc() ; //read last value
   a2d_chan++ ;
      if (a2d_chan > LAST_CHANNEL)
         a2d_chan = 0 ;                     //select the next channel
         set_adc_channel(a2d_chan) ;       //circularly read the analog channels
however in the main loop, after calling it, it fails to work as expect. Below is the program
#include <16f877.h>
#device adc=10
#device *=16
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOBROWNOUT                 //Reset when brownout detected
#use fast_io(A)
//************************ Varriables Declaration ***************************//
#define STATUS_LED         PIN_C2
#define START_BUTTON      PIN_B0
#define RESET_BUTTON       PIN_B1
/*********** BRAKE voltage min 1.75V ******/
#define BRAKE_MIN (int16)((1.75/5.0)*1023)
/******** 4.25V is the most to be read from the Brake */
#define BRAKE_MAX (int16)((4.25/5.0)*1023)
enum {BATTERY , BRAKE, TEMP , AUX_INPUT } ; // analog data channel s
#define LAST_CHANNEL AUX_INPUT
int a2d_chan, BRAKE_FAULT;
int1 flag_error, flag_system_fault;
int16 analog_data[LAST_CHANNEL+1] ;
   a2d_chan++ ;
   setup_spi(spi_ss_disabled);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(t1_disabled);
   setup_timer_2(t2_disabled,0,1);
   setup_adc(adc_clock_internal);
   setup_ccp1(ccp_off);
   setup_ccp2(ccp_off);
   setup_adc(ADC_CLOCK_DIV_8 );     // Setup ADC
   setup_adc_ports(ALL_ANALOG);
   get_analog_data() ; //circularly service the A/D channels
      if((analog_data[BRAKE]< BRAKE_MIN) || (analog_data[BRAKE] > BRAKE_MAX))
          flag_system_fault = 1 ;          //set fault flag
          flag_error = BRAKE_FAULT ;       //Brake input error detected
          output_bit(STATUS_LED , 1 ) ; // status light ON
How can it be able to make this code work,
PostPosted: Thu Oct 08, 2020 6:44 am     Reply with quote
OK.
First, change your ADC channel setup to use 'AN0_AN1_AN2_AN3_AN4'
instead of 'ALL_ANALOGS'. You are setting lots of unwanted pins up as
analog inputs which will increase noise in the ADC. This still leaves one
extra pin selected, but a lot better than having lots selected.
Then your SPI setup is wrong. Second person today making the same
error. The setting to turn off the spi is:
setup_spi(FALSE);
You are enabling the SPI with the slave select disabled....
Then your ADC clock setting is wrong. At 20MHz, you need to be using
ADC_CLOCK_DIV_32, not 'internal'. Internal is not recommended for
use above 1MHz. You currently have two clock lines, the first selecting
internal, and the second /8. Both are wrong. Remove both and just have
one line selecting /32.
Then you are not allowing enough time for acquisition between selecting
the channel and reading. The chip needs a minimum of 19.72uSec
between the instruction that selects the channel and actually taking the
reading. You have a few instructions to the loop, but probably no more
than a couple of uSec.
Also, as shown, your very first reading has no ADC channel selected....
colesha
PostPosted: Mon Oct 12, 2020 9:29 am     Reply with quote
Ttelmah wrote:
OK.
setup_spi(FALSE);
Thanks Ttelmah for the guidelines. I managed to set the PIC as per your suggestion and it worked as expected.
Am using the enumeration which has all the adc channels set and read in here
   a2d_chan++ ;
The channels are automatically selected from this enumeration
int a2d_chan;
PostPosted: Mon Oct 12, 2020 10:03 am     Reply with quote
The point is that the first time you do the 'read' no set_adc_channel
has been called. So the first read will return garbage. After that it'll
all start working fine. You set the next channel at the exit from the routine.
Glad you have it working now.
