David Lu Guest
| 16F877 internal EEPROM can't write/read |
Posted: Wed Feb 26, 2003 7:49 pm |
Hi,All:
I am trying to use C language to write and read internal EEPROM on my 16f877, but it can not working.
my program is:
void write_eeprom ( char addr, char data ) // Write eeprom
while ( EECON1 & WR); // check completion of last write
EEADRH=0x21;
EEADR = addr; // set address register
EEDATA = data; // set data register
clear_bit ( EECON1, EEPGD );
set_bit( EECON1, WREN );
EECON2 = 0x55;
EECON2 = 0xAA;
set_bit( EECON1, WR ); // write command
clear_bit( EECON1, WREN ); // inhibit further writing
char read_eeprom ( char addr ) // Read eeprom
{ EEADRH=0x21;
clear_bit (EECON1, EEPGD );
set_bit(EECON1, RD ); // read command
return (EEDATA);
Is there any special setting for MPLAB ?
Thanks!
David
___________________________
Original Post ID: 12151 |
ajt
| Re: 16F877 internal EEPROM can't write/read |
Posted: Wed Feb 26, 2003 7:58 pm |
Why not use the built in read and write EEPROM functions provided in the CCD compiler? All you are trying to do is embodied in them and they work fine.
:=Hi,All:
:= I am trying to use C language to write and read internal EEPROM on my 16f877, but it can not working.
:= my program is:
:=void write_eeprom ( char addr, char data ) // Write eeprom
:= while ( EECON1 & WR); // check completion of last write
:= EEADRH=0x21;
:= EEADR = addr; // set address register
:= EEDATA = data; // set data register
:= clear_bit ( EECON1, EEPGD );
:= set_bit( EECON1, WREN );
:= EECON2 = 0x55;
:= EECON2 = 0xAA;
:= set_bit( EECON1, WR ); // write command
:= clear_bit( EECON1, WREN ); // inhibit further writing
:=char read_eeprom ( char addr ) // Read eeprom
:={ EEADRH=0x21;
:= clear_bit (EECON1, EEPGD );
:= set_bit(EECON1, RD ); // read command
:= return (EEDATA);
:= Is there any special setting for MPLAB ?
:=Thanks!
:=David
Original Post ID: 12152 _________________ Al Testani |
Mark
Posted: Wed Feb 26, 2003 8:48 pm |
This line is probably incorrect. You probably have WR defined as a bit position in which case it should be
while (bit_test(EECON1, WR));
Also since you are not writing to the program memory, the following line is not needed:
:= EEADRH=0x21;
Microchip also recommends disabling global ints before writing 0x55 and 0xAA to EECON2 and reenabling them after startin the write operation. If they suggest it, they probably have found the likelyhood of problems if you don't.
Mark
:=Hi,All:
:= my program is:
:= EEADRH=0x21;
:= EECON2 = 0x55;
:= EECON2 = 0xAA;
:={ EEADRH=0x21;
:= return (EEDATA);
:=Thanks!
:=David
Original Post ID: 12154 |
David Lu Guest
| Thanks Mark |
Posted: Wed Feb 26, 2003 9:04 pm |
Mark:
Thanks!
I will try it tomorrow in company.
David
Original Post ID: 12155 |
David Lu Guest
| 16F877 internal EEPROM still can't write/read |
Posted: Thu Feb 27, 2003 7:42 pm |
Hi,Mark:
I try it today,but still not working.
I use MPLAB IDE , I try to change some items of ICD Options,and put high voltage on MCLR/Vpp(Pin 1 of 16F877),but
when I check the EEPROM (in EEPROM Window), each unit is still 0xFF, EECON1 and EECON2 does not changed.
I want get some help to solve my problem.
David
Original Post ID: 12197 |
Thomas Hartmann Guest
Posted: Fri Feb 28, 2003 3:04 am |
Hi David,
the same problem you have has const me 2 days of debugging, this week.
I use a 16F876 with the in circuit debugger "ICD" from Microchip + MPLAB 5.0.
This is how I solved the problem:
1. MPLAB does NOT automatically update the EEPROM Window.
You have to update it manually. Since I use the ICD I have a window open to control the ICD. There I have to set a tick to a box called "EEPROM Data" and then click a button called "Read".
2. I precicely followed the instructions from the 16F876's data sheet on writing the EEPROM.
I also watched the EEDATA- and the EEADR-registers to see if my data and the destination address was loaded at all.
After knowing they were loaded into these registers I focused on why it was not written etc. Step by step.
For your reference, I will attach my ( working! ) code
Thomas
------------ < CODE > -------------------------------
// liest Daten aus dem EEprom
//#inline
void read_eeprom_data( unsigned int8 un8Start, unsigned int8 un8Length, unsigned int8* pun8Dest )
unsigned int8 i;
// disable interrupts
disableInterrupts_Timer1_RS232();
// set destination to "EEPROM" by clearing EEPGD in EECON1
EECON1 &= ~EECON1_EEPGD;
// read data
for( i=0; i<un8Length; i++)
// write address to register
// compiler will select bank 2
EEADR = un8Start + i ; // set destination address (EEPROM)
// read NOW !
EECON1 |= EECON1_RD;
// get data from register
*(pun8Dest + i) = EEDATA;
// enable interrupts
enableAllInterrupts();
// write data to EEprom
// see also data sheet of the PIC16F873A, 3.4 Writing to Data EEPROM Memory
//#inline
void write_eeprom_data( unsigned int8 un8Start, unsigned int8 un8Length, unsigned int8* pun8Src )
unsigned int8 i;
unsigned int8 debugData; // DEBUG
// enable writing of EEPROM -> set WREN bit in EECON1 register
EECON1 |= EECON1_WREN;
// write data
//for( i=0; i<10; i++)
// wait until previous write is complete
while( EECON1 & EECON1_WR )
// simply don't nothing. Should not take longer than typ.4msec, max.8ms ( data sheet )
disableAllInterrupts(); // prevent writing of rubbish
// write address and data to registers
EEDATA = *(pun8Src + i); // set data that has to be written
// clear write error flag
EECON1 &= ~EECON1_WRERR;
// magic write sequence
EECON2 = 0x55; // special command 1
EECON2 = 0xAA; // special command 2
EECON1 |= EECON1_WR; // set WR bit => WRITE!
enableAllInterrupts(); // interrupts may be enabled until we are ready to write the next byte
// disable ( accidental ) writing of EEPROM -> clear WREN bit in EECON1 register
EECON1 &= ~EECON1_WREN;
// set destination back to "PROGRAM MEMORY" by setting EEPGD in EECON1
EECON1 |= EECON1_EEPGD;
// clear interrupt flag
PIR2 &= ~PIR2_EEIF;
----------------< /CODE >----------------------------
:=Hi,All:
:= my program is:
:= EEADRH=0x21;
:= EECON2 = 0x55;
:= EECON2 = 0xAA;
:={ EEADRH=0x21;
:= return (EEDATA);
:=Thanks!
:=David
Original Post ID: 12207 |
