Issues with software PWM for microservo
lucke
PostPosted: Tue Aug 25, 2020 7:12 pm     Reply with quote
Hi all,
I'm trying to make PWM software to control a "9g" microservo, but it's not working (the servomotor does not change the angle correctly):
Servo details:
Freq: 50hz/20ms period
-90° -> 1ms pulse
0° -> 1,5ms pulse
90° -> 2ms pulse
my reasoning:
tControlServo = (2ms-1ms) = 1ms/180° = 5,6us/1°
= 56us/10°
timer0 overflow -> 56us
overflow = 4 * (preSc) * (256 - load) / 4 000 000
56 us = 4*4*(256-load)/4000000
load = 242
timer0 "ticks":
ticks = 1000us / 56us
ticks = ~18 -> For ~1ms
18ticks -> -90°
27ticks -> 0°
36 ticks -> 90°
My code:
#include <12f683.h>
#fuses NOMCLR, NOPUT, NOBROWNOUT, NOCPD, XT
#use delay(clock=4MHz)
#use fast_io(A)
#define pinoServo PIN_A1
int1 active = 0;
int8 nOk = 18;
int16 ticks = 0;
#INT_TIMER0
void timer0_isr(){
set_timer0(242);
ticks++;
 if ((ticks >= 0) && (ticks <= 18) && (active == 0)){ //~1ms
 output_bit(pinoServo, 1);
 active = 1;
 }else
 if ((ticks > nOk) && (active == 1)){
 output_bit(pinoServo, 0);
 active = 0;
 }else
 if ((ticks > 36) && (active == 1)){ //~2ms
 active = 0;
 }else
 if (ticks >= 357){
 ticks = 0; //~20ms
void conf(){
set_tris_a(0);
output_low(PIN_A0);
output_low(PIN_A1);
output_low(PIN_A2);
setup_timer_0(T0_INTERNAL|T0_DIV_4);
set_timer0(242);
void main(){
conf();
 while (true){
  for (int8 i=0; i <= 18; i++){
  nOk = 18+i;
Hardw: PIC12F683 + (4MHz xtal and 33pF caps)
my reasoning or my code is wrong (or both? Laughing )
PostPosted: Tue Aug 25, 2020 7:44 pm     Reply with quote
Look at the .LST file. It takes longer than 56us to process the interrupt.
lucke
PostPosted: Tue Aug 25, 2020 9:30 pm     Reply with quote
It would be 57 instructions (and 57us) (0x6E-0x36+1)?
This means that changing the processing location (to main() for example) would also not work, right?
PostPosted: Wed Aug 26, 2020 12:02 am     Reply with quote
It takes about 50 instructions just for interrupt overhead code.
At 4 MHz, this is 50us. Then you have your isr user code on top of that.
Your isr user code takes way more than 6us to run.
Why not use the internal oscillator (as a test) and set it to 8 MHz with this:
#use delay(internal = 8M)
Get rid of the XT fuse.
Then change your Timer0 divisor to 8, as follows:
setup_timer_0(T0_INTERNAL | T0_DIV_8);
This combination will give you the same 250 KHz clock rate for Timer0.
The 242 preload value can stay the same.
But the interrupt overhead code will now execute in 25us. Your user code
might now run fast enough to be less than 31us (25 + 31 = 56us).
I'd suggest going to a 20 MHz crystal with the HS fuse. Then you'll have
enough time to do the interrupt, and have some processing time left over
for any tasks in main().
PostPosted: Wed Aug 26, 2020 1:47 am     Reply with quote
As an alternative to the PWM, consider using the CCP.
I posted a basic code to use a CCP channel to control a servo, here:
<http://www.ccsinfo.com/forum/viewtopic.php?t=50914&highlight=servo>
This makes the system only interrupt every pulse, not every count (using
the hardware CCP, to change the signal).
Might be worth looking at. Very Happy
lucke
PostPosted: Wed Aug 26, 2020 8:47 am     Reply with quote
Hm.. ok, I understand the 50us part ((1/4M)*4 for instruction), but I couldn't see it in the lst file..
It would be this lines?
................... #INT_TIMER0
.................... void timer0_isr(){
.................... set_timer0(242);
0036:  MOVLW  F2
0037:  MOVWF  01
.................... ticks++;
0038:  INCF   2E,F
0039:  BTFSC  03.2
003A:  INCF   2F,F
I'll make changes as soon as I have time and test the code
Thanks a lot, I looked at your code, I will test it too.
I'm actually using 683 just to test the code, I intend to migrate the program to a 16f688 (UART rc car project, which I'm even suffering due to noise) and it doesn't have the ccp module Mad Would using the same idea but using only timers work?
Thanks to those who are helping.
PostPosted: Wed Aug 26, 2020 8:54 am     Reply with quote
You posted a piece of your user code.
The code that takes about 50us to run is the interrupt overhead code as
shown below:
// Enter here when a Timer0 interrupt occurs.
// Save the state of the machine.
0004:  BTFSC  STATUS.RP0
0005:  GOTO   00A
0006:  MOVWF  24
0007:  SWAPF  STATUS,W
0008:  MOVWF  25
0009:  GOTO   00F
000A:  BCF    STATUS.RP0
000B:  MOVWF  24
000C:  SWAPF  STATUS,W
000D:  MOVWF  25
000E:  BSF    25.1
000F:  MOVF   PCLATH,W
0010:  MOVWF  2B
0011:  CLRF   PCLATH
0012:  BCF    STATUS.IRP
0013:  SWAPF  24,F
0014:  MOVF   FSR,W
0015:  MOVWF  26
0016:  MOVF   @20,W
0017:  MOVWF  27
0018:  MOVF   @21,W
0019:  MOVWF  28
001A:  MOVF   @22,W
001B:  MOVWF  29
001C:  MOVF   @23,W
001D:  MOVWF  2A
001E:  BCF    STATUS.RP0
001F:  BTFSS  INTCON.T0IE
0020:  GOTO   023
0021:  BTFSC  INTCON.T0IF
0022:  GOTO   036    // Jump to user code in #int_timer0
// Arrive here when code in #int_timer0 is done.
// Restore the state of the machine.
0023:  MOVF   26,W
0024:  MOVWF  FSR
0025:  MOVF   27,W
0026:  MOVWF  @20
0027:  MOVF   28,W
0028:  MOVWF  @21
0029:  MOVF   29,W
002A:  MOVWF  @22
002B:  MOVF   2A,W
002C:  MOVWF  @23
002D:  MOVF   2B,W
002E:  MOVWF  PCLATH
002F:  SWAPF  25,W
0030:  MOVWF  STATUS
0031:  BCF    STATUS.RP0
0032:  SWAPF  24,W
0033:  BTFSC  25.1
0034:  BSF    STATUS.RP0
0035:  RETFIE     // Return to the main program
lucke
PostPosted: Sat Sep 19, 2020 5:34 pm     Reply with quote
First, I would like to apologize for the time it took me to respond, I got busy and ended up putting the project aside...
Secondly, I would like to thank you for your efforts in helping me. The suggestion worked!
I am still lost in relation to the assembler (.lst file), but your help has clarified a lot.
Thanks PCM programmer and Ttelmah! Very Happy
