dipen
| AD CONVERTION USING PIC452 |
Posted: Wed Feb 18, 2004 6:43 pm |
im using mplab 6.3v with ccs compiler 3.155v with a pic18f452, and
im trying to complete A/d convertions on 7 channels. im getting these errors
*** Error 76 "ADC2.c" Line 65(15,23): Expect ;
*** Error 76 "ADC2.c" Line 70(15,23): Expect ;
which is my read adc statement for acc6, and acc7 which are port e..E0,E1.
is there something that im missing regarding those parts in my code
listed below. if i dont use port e, the project builds. Please help thank you
#define INTS_PER_SECOND 8 // (4000000/(4*2*65536))
byte seconds; // A running seconds counter
byte int_count; // Number of interrupts left before a second has elapsed
#int_rtcc // This function is called every time
rtcc_isr() { // the RTCC (timer0) overflows (255->0).
// For this program this is apx 15 times
if(--int_count==0) { // per second.
++seconds;
int_count=INTS_PER_SECOND;
byte start;
int16 acc1, acc2, acc3, acc4, acc5, acc6, acc7;
setup_adc_ports( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
enable_interrupts(INT_RTCC);
setup_counters( RTCC_INTERNAL, RTCC_DIV_2);
set_rtcc(0);
do{
set_adc_channel( 0 );
delay_us(15);
acc1 = Read_ADC();
printf("1%2X ",acc1);
set_adc_channel( 1 );
delay_us(15);
acc2 = Read_ADC();
printf("2%2X ",acc2);
etc
start=seconds;
printf("T%u ",start);
}while(true);
could it be that something is wrong with my timing??? not sure right now _________________ nick |
Posted: Thu Feb 19, 2004 6:18 pm |
| Quote: | im using mplab 6.3v with ccs compiler 3.155v with a pic18f452, and
*** Error 76 "ADC2.c" Line 70(15,23): Expect ; |
The problem could be due to the compiler version, 3.155.
See the following thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=4499&highlight=155 |
