pic18F26K22 ADC 10-bit resolution!?
RoMar
PostPosted: Sun Aug 16, 2020 1:23 pm     Reply with quote
I'm using ccs (5.008 version) to program a pic18F26K22.
I need to use an ADC. In datasheet I can see this PIC has a ADC with 10-bit.
With this ADC, I want to read voltage's values from 1 to 5Volts with voltage divider circuit.
The resolution is 0-1024 (Full-Scale Range).
But with the code below I just have values from 1 to 255, this means just 8-bit wide!!?
At value's ADC 255 corresponds to 1,23 Volts. And when the voltage is greater than 1.23V,
the ADC gives again a lower values, ( lower than 255 ) something is missing here
(some values are in the table below).
I think I'm doing right. I tried many ways to get 10-bit resolution, but I just have 8-bits??!
The CCS code is below. I can't understand what is missing here, please I need some help.
    __U___|__ADC(bit)_|_ U_adc__ [adc U_float]__multimeter
    0.494V__|____ 104___|_ 49___|___0.4929___|__0.50V
    0.618V__|____ 130___|_ 61___|___0.6162___|__0.63V
    0.782V__|____ 166___|_ 78___|___0.7868___|__0.80V
    1.146V__|____ 242___|_ 114 _|___1.1470___|__1.16V
    1.206V__|____ 255___|_ 120__|___1.2087___|__1.23V
    0.120V__|____ 26____|_ 12___|___0.1232___|__1.38V ---->X
    0.120V__|____ 27____|_ 12___|___0.1279___|__1.38V ---->X
    0.284V__|____ 61____|_ 28___|___0.2891___|__1.54V ---->X
#include <18F26K22.h>
#fuses  HSH, PLLEN, NOLVP, NOPROTECT, NOWDT, NOXINST
#device ADC=10
#use delay(crystal=12MHz, clock=48MHZ) //cristal de 12MHz
#use rs232(stream=UART_1,baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include "lcd.c"
void tabela(void);
int main(){
   unsigned int8 value_ADC, adcU;
   float adcUFloat;
   char valorU[6]="     V";
   setup_adc_ports( sAN0 | VSS_VDD );
   setup_adc(ADC_CLOCK_DIV_16);
   delay_ms(5000);
   tabela();
   for(;;){
         set_adc_channel(0);
         delay_ms(1);
         value_ADC = read_adc();
         adcU = value_ADC*0.474;
         adcUFloat = value_ADC*0.00474;
         valorU[0] = adcU/100%10+48;
         valorU[1] = ".";
         valorU[2] = adcU/10%10+48;
         valorU[3] = adcU%10+48;
         valorU[4] = adcU*10%10+48;
         printf("\t %c",valorU[0]);
         printf("%c",valorU[1]);
         printf("%c",valorU[2]);
         printf("%c",valorU[3]);
         printf("%c",valorU[4]);
         printf("%c",valorU[5]);
         printf("\t |\t %u ", value_ADC);
         printf("\t |\t %u ", adcU);
         printf("\t |\t %0.4f \r\n", adcUFloat);
         lcd_gotoxy( 5, 1);
         printf(lcd_putc, valorU);
         lcd_gotoxy( 11, 1);
         printf(lcd_putc, " .....");
         delay_ms(5000);
   return 0;
void tabela(){
   lcd_gotoxy(1, 1);
   printf(lcd_putc, "                ");
   lcd_gotoxy(2, 1);
   printf(lcd_putc, "U=      ");
   printf("\r\n");
   printf("\t      U");
   printf("\t          ADC(bit)   ");
   printf("\t           U_adc    ");
   printf("\t         adc U_float  \r\n");
Best Regards[/list]
Re: pic18F26K22 ADC 10-bit resolution!?
PostPosted: Sun Aug 16, 2020 1:34 pm     Reply with quote
Look closely at this and you'll see what's wrong:
RoMar
PostPosted: Sun Aug 16, 2020 2:10 pm     Reply with quote
In first place, thanks for your time and help,
Of course,
int8 -> 0 - 255
I change to int16 -> 0 to 65535
and
printf("\t |\t %Lu ", value_ADC);
printf("\t |\t %Lu ", adcU);
and everything is working,
well, I'm new here, thus mistakes are very close to me yet.
Thanks a lot.
