hemnath
| How to display IEEE 754 in RS232 |
Posted: Thu Aug 06, 2020 6:03 am |
How to display the IEEE in RS232
| Code: | #include "18F2520.h"
#fuses HS
#use delay(clock=12000000)
#include "ieeefloat.c"
float f;
int32 PCval;
int8 *p;
f = 0.0123;
PCval=f_PICtoIEEE(f);
printf("IEEE %Ld",PCval);
printf("\n\r");
Posted: Thu Aug 06, 2020 8:46 am |
Display how?.
If you want to print the fp value, then don't. Just print your variable 'f'.
If you want the hex values that the IEEE representation has, then just
print with &08x:
printf("IEEE %08x",PCval);
This then gives the hex digits corresponding to the IEEE value. |
hemnath
Posted: Thu Aug 06, 2020 11:10 pm |
I get this result, IEEE 000000f0
I guess, for float 0.0123, IEEE hex is 0x3c4985f0 |
Posted: Thu Aug 06, 2020 11:18 pm |
| It has to be "lx", not "x". Then it will work. |
hemnath
Posted: Thu Aug 06, 2020 11:56 pm |
perfect. Thanks!
Is it possible to display the value in binary format? |
Posted: Fri Aug 07, 2020 1:28 am |
Binary!...
You do realise you'll have 32bits for each number. Not exactly convenient to
do anything with....
You'd have to generate your own binary output routine. Not exactly hard:
void binary(unsigned int32 value)
unsigned int32 mask=0x80000000;
do {
if (mask & value)
putc('1');
putc('0');
mask/=2;
} while (mask!=0);
