how to receive string from PC using RS232
hemnath
PostPosted: Wed Jul 22, 2020 10:41 pm     Reply with quote
#include "18F2520.h"
#fuses INTRC_IO
#use rs232(baud=9600,parity=N,xmit=pin_c6,rcv=pin_c7,bits=8, Errors, stream=PC)
   float value = 32.000;
   int i = 0, j;
   char unit[] = "BAR";
   printf("Enter 1 or 2 to display the following\n\r");
   printf("1. PROCESS VALUE\n\r");
   printf("2. UNITS\n\r");
      i = 0;
      if(kbhit())
         j = getc();
         if(j == '1')
            printf("Process Value: %8f\n\r",value);
         else if(j == '2')
            while(unit[i] != '\0')
               putc(unit[i]);                            // Write character
               i++;
            printf("\n\r");
            putc(j);
            printf("\r\nBAD COMMAND\n\r");
This code is working good with receiving a character. How to receive string?
Mike Walne
PostPosted: Thu Jul 23, 2020 2:49 am     Reply with quote
Examples supplied by CCS shows you how to do it.
You've been around for eight years, you should not need to be asking.
Mike
mdemuth
PostPosted: Wed Jul 29, 2020 5:37 am     Reply with quote
// Receive data
   for (rx_buffid=0; rx_buffid < RX_BUFFER_LENGTH; rx_buffid++) rx_buffer[rx_buffid]=0; // empty the buffer
   rx_complete = false;
   while (rx_complete == false)
    if (kbhit())
      rx_character = getc();      // Character into buffer
      if (rx_character == '*' || rx_character == '#') rx_buffid = 0;   // start identifier '*' = reset pointer
      else  rx_buffid++; // increment buffer pointer
      if (rx_buffid > RX_BUFFER_LENGTH) rx_buffid = RX_BUFFER_LENGTH;
      rx_buffer[rx_buffid] = rx_character; // prevent buffer overflow
      if (rx_character == 0x0d) rx_complete = true; // CR => end of telegram, start analysis
      // do something else...maybe increment a timeout counter.....
    restart_wdt();
// Interpretation
