ressas
Posted: Tue Jul 28, 2020 11:56 pm |
Last question(maybe)
| Quote: |
W5500 has Common Register, 8 Socket Register, TX/RX Buffer Block for each Socket. | (datasheet page 15)
What should I understand from 8 socket register expressions here.
their differences are not specified.
Is it a problem to use a single socket throughout the program?
I think I will use tx while writing, and rx when reading.
When I first read it, I understood that I could plug 8 different sockets into an integrated device.
https://lh3.googleusercontent.com/proxy/EDXUnW5sfh5Lw_susbi0RocW5QvbxgBsmd9xelYUlGy9ZWPeggCCmGXNVYOSvDYisEfmTxSTe1LBVXu4gsIvrdjTCZfXU_VCSkqMdKN4TrUtsyU4YE80aFO741_FSWkN_VuiWk_YirqejZfHrajQNBhTxYhH80sSBk6AByc_J0G-Q4gZFO08VBZ1cRNyB0E
AND
If I have something missing, please correct it.
unsigned int8 w5500_read(unsigned int16 address){
unsigned int8 data;
output_low(_pinSCS);
spi_xfer(w5500,address,16);
spi_xfer(w5500, BLOCK(0) | READ | VDMN,8);
data = spi_xfer(w5500,0x0,8);
output_high(_pinSCS);
return data;
void w5500_write(unsigned int16 address,unsigned int8 data){
spi_xfer(w5500, BLOCK(0) | WRITE | VDMN,8);
spi_xfer(w5500,data,8);
Posted: Wed Jul 29, 2020 12:46 am |
These are not physical 'sockets'. These are logical connections.
In networking, a 'socket;, is a logical connection.
<https://www.quora.com/In-simple-terms-what-is-a-socket-in-networking>
Each connection setup to/from the device, is a separate 'socket'.
Once you setup a TCP connection for example, this is a 'socket'.
Now a single socket may be possible, but for a lot of things 'no'. If
for example you have a TCP connection and use UDP, this will be
two sockets. |
ressas
Posted: Wed Jul 29, 2020 8:07 am |
One more thing.
The socket and Common registers provided in Datasheet have the same addresses. What should I do to separate them
#define MR 0x0000 //mode register
#define GAR1 0x0001 //Gateway IP Address 192.168.0.1
#define GAR2 0x0002
#define GAR3 0x0003
#define GAR4 0x0004
//////////////Socket Registers////////////////
#define Sn_MR 0x0000 //Socket n Mode
#define Sn_CR 0x0001 //Socket n Command
#define Sn_IR 0x0002 //Socket n Interrupt
#define Sn_SR 0x0003 //Socket n Status
#define Sn_PORT1 0x0004 //Socket n Source Port
#define Sn_PORT2 0x0005
Progress:
I proceed as shown on the page below. I am currently writing a value to a register and reading it. (A simple event.)
But I got stuck in the socket register section
https://wizwiki.net/wiki/doku.php/products:w5500:application:tcp_function |
Posted: Wed Jul 29, 2020 8:16 am |
Yes, they have the same address. They are in different blocks....
Look at section 2.2.2 'Control Phase'.
Block 0 accesses the common registers.
Block 1 Socket 0 registers
Block 5 Socket 1
etc. etc.
The block locations for the Socket N register block is (n*4)+1. The RX block
(n*4)+2, the TX block (n+4)+3 |
ressas
Posted: Wed Aug 05, 2020 1:32 am |
Thank you Ttelmah. I look the control phase.
When I set Block select bits to 0x00, I access common registers. In other cases, I access socket registers. (As I understand).
By following the steps in the link below, I came to the "SOCKET Initialization" section.
I don't know how to write expressions like "OPEN" - "CLOSE" to the sn_CR register. And what path should I follow ?
Please look this link:
Secondly, I'm not sure about "Set socket memory information".
wiznet.h
#define _pinCLK pin_C3
#define _pinSDI pin_C4
#define _pinSDO pin_C5
#define _pinSCS pin_D0
#define BLOCK(x) (x<<3)
#define WRITE 4
#define READ 0
#define VDMN 0
#define FDL1 1
#define FDL2 2
#define FDL4 3
// Common Register
#use SPI(MASTER, DO=_pinSDO, DI = _pinSDI, CLK=_pinCLK, baud=1000000, bits=16, MODE=2, stream=w5500)
#define GAR2 0x0002
#define GAR3 0x0003
#define GAR4 0x0004
#define SUBR1 0x0005 //Subnet Mask 255.255.255.0
#define SUBR2 0x0006
#define SUBR3 0x0007
#define SUBR4 0x0008
#define SHAR1 0x0009 //Source Hardware Address 00.08.DC.01.02.03
#define SHAR2 0x000A
#define SHAR3 0x000B
#define SHAR4 0x000C
#define SHAR5 0x000D
#define SHAR6 0x000E
#define SIPR1 0x000F //Source IP Address 192.168.0.2
#define SIPR2 0x0010
#define SIPR3 0x0011
#define SIPR4 0x0012
#define INTLEVEL1 0x0013 //Interrupt Low Level Timer
#define INTLEVEL2 0x0014
#define IR 0x0015 //Interrupt
#define IMR 0x0016 //Interrupt Mask
#define SIR 0x0017 //Socket Intterrupt
#define SIMR 0x0018 //Socket Interrupt Mask
#define RTR1 0x0019 //Retry Time-value
#define RTR2 0x001A
#define RCR 0x001B //Retry Count
#define PTIMER 0x001C //PPP Link Control Protocol Request Timer
#define PMAGIC 0x001D //PPP Link Control Protocol Magic number
#define PHAR1 0x001E //Destination Hardware Address Register in PPPoE mode)
#define PHAR2 0x001F //00:08:DC:12:34:56
#define PHAR3 0x0020
#define PHAR4 0x0021
#define PHAR5 0x0022
#define PHAR6 0x0023
#define PSID1 0x0024 //Session ID Register in PPPoE mode)
#define PSID2 0x0025 //
#define PMRU1 0x0026 //Maximum Receive Unit in PPPoE mode
#define PMRU2 0x0027
#define UIPR1 0x0028 //Unreachable IP Address
#define UIPR2 0x0029
#define UIPR3 0x002A
#define UIPR4 0x002B
#define UPORTR1 0x002C //Unreachable Port
#define UPORTR2 0x002D
#define PHYCFGR 0x002E //W5500 PHY Configuration
#define VERSIONR 0x0039 //W5500 Chip Version
#define Sn_DHAR1 0x0006 //Socket n Destination Hardware Address
#define Sn_DHAR2 0x0007
#define Sn_DHAR3 0x0008
#define Sn_DHAR4 0x0009
#define Sn_DHAR5 0x000A
#define Sn_DHAR6 0x000B
#define Sn_DIPR1 0x000C //Socket n Destination IP Address
#define Sn_DIPR2 0x000D
#define Sn_DIPR3 0x000E
#define Sn_DIPR4 0x000F
#define Sn_DPORT1 0x0010 //Socket n Destination Port
#define Sn_DPORT2 0x0011
#define Sn_MSSR1 0x0012 //Socket n Maximum Segment Size
#define Sn_MSSR2 0x0013
#define Sn_TOS 0x0015 //Socket n IP Type of Service
#define Sn_TTL 0x0016 //Socket n TTL
#define Sn_RXBUF_SIZE 0x001E //Socket n RX Buffer Size
#define Sn_TXBUF_SIZE 0x001F //Socket n TX Buffer Size
#define Sn_TX_FSR1 0x0020 //Socket n TX Free Size
#define Sn_TX_FSR2 0x0021
#define Sn_TX_RD1 0x0022
#define Sn_TX_RD2 0x0023
#define Sn_TX_WR1 0x0024 //Socket n TX Write Pointer
#define Sn_TX_WR2 0x0025
#define Sn_RX_RSR1 0x0026 //Socket n Received Size
#define Sn_RX_RSR2 0x0027
#define Sn_RX_RD1 0x0028 //Socket n RX Read Data Pointer
#define Sn_RX_RD2 0x0029
#define Sn_RX_WR1 0x002A
#define Sn_RX_WR2 0X002B
#define Sn_IMR 0x002C //Socket n Interrupt Mask
#define Sn_FRAG1 0x002D //Socket n Frafment
#define Sn_FRAG2 0x002E
#define Sn_KPALVTR 0x002F //Socket n Keep Alive Time
unsigned int8 w5500_read(unsigned int16 address, unsigned int8 blockData);
void w5500_write(unsigned int16 address,unsigned int8 data, unsigned int8 blockData);
void start_setting();
void basic_setting();
void network_setting();
void socket_setting();
wiznet.c
#include "w5500.h"
unsigned int8 w5500_read(unsigned int16 address,unsigned int8 blockData){
unsigned int8 data;
delay_cycles(1);
spi_xfer(w5500, BLOCK(blockData) | READ | VDMN,8);
return data;
void w5500_write(unsigned int16 address,unsigned int8 data, unsigned int8 blockData){
delay_cycles(1);
spi_xfer(w5500, BLOCK(blockData) | WRITE | VDMN,8);
void start_setting(){
//start setting
w5500_write(PHYCFGR,0xB8,0x00); //step 1 PHYCFGR config
void basic_setting(){
//basic setting
w5500_write(MR , 0x00 , 0x00); //step 2 MR config
w5500_write(IMR , 0x00 , 0x00); //step 3 IMR config
w5500_write(RTR1, 0x0F , 0x00); //step 4 RCR config
w5500_write(RTR2, 0xA0 , 0x00);
void network_setting(){
//Network Information setting
w5500_write(SHAR1,0x00,0x00); //step 5 SHAR config
w5500_write(SHAR2,0X08,0x00);
w5500_write(SHAR3,0xDC,0x00);
w5500_write(SHAR4,0x01,0x00);
w5500_write(SHAR5,0x02,0x00);
w5500_write(SHAR6,0x03,0x00);
w5500_write(GAR1,0xC0,0x00); // 192 . 168 . 0 . 1
w5500_write(GAR2,0xA8,0x00); // 168
w5500_write(GAR3,0x00,0x00); // 0
w5500_write(GAR4,0x01,0x00); // 1
w5500_write(SUBR1,0xFF,0x00); // 255 . 255 . 255 . 0
w5500_write(SUBR2,0xFF,0x00); // 255
w5500_write(SUBR3,0xFF,0x00); // 255
w5500_write(SUBR4,0x00,0x00); // 0
w5500_write(SIPR1,0xC0,0x00); // 192 . 168 . 0 . 2
w5500_write(SIPR2,0xA8,0x00); // 168
w5500_write(SIPR3,0x00,0x00); // 0
w5500_write(SIPR4,0x02,0x00); // 2
void socket_setting(){
//do{ //Sn_CR = CLOSE;
start:
w5500_write(Sn_MR , 0x01,0x00); //
w5500_write(Sn_PORT1,0xAB,0x00); //
w5500_write(Sn_PORT2,0x00,0x00); //
w5500_write(Sn_CR , 0x01,0x00); //
if(Sn_SR != "SOCK_INIT"){
//Sn_CR = "CLOSE";
goto start;
//}while(Sn_SR != "SOCK_INIT");
wiznet_main.c
#include <18F46k22.h>
#device ADC=12
#fuses NOWDT,NOBROWNOUT,PUT,NOWRT,NODEBUG,INTRC_IO, NOMCLR, NOPROTECT, NOWDT, NOLVP,PLLEN
#use delay(internal=64000000)
#include "w5500.c"
unsigned int16 S0_RXMEM_SIZE = 0;
unsigned int16 S0_TXMEM_SIZE = 0;
#locate S0_RXMEM_SIZE = 0x80
#locate S0_TXMEM_SIZE = 0x82
setup_oscillator(OSC_64MHZ , OSC_PLL_ON);
setup_adc_ports(NO_ANALOGS,VSS_VDD);
start_setting(); //start setting
basic_setting(); //basic setting
network_setting(); //Network Information setting
//socket_setting(); //SOCKET REGISTER
unsigned int16 r1,r2,r3,r4;
while(true)
r1 = w5500_read(GAR1,0x00); // 192 . 168 . 0 . 1
delay_us(20);
r2 = w5500_read(GAR2,0x00); // 168
delay_us(20);
r3 = w5500_read(GAR3,0x00); // 0
delay_us(20);
r4 = w5500_read(GAR4,0x00); // 1
delay_us(20);
printf("V: %ld %ld %ld %ld\n",r1,r2,r3,r4);
printf("%ld\n",Sn_SR);
delay_ms (2000);
ressas
Posted: Wed Aug 05, 2020 8:35 pm |
any answers  |
Posted: Thu Aug 06, 2020 1:31 am |
Seriously, this is called programming.
You are going to have to get the existing library from the Wiznet site, and
modify this for the PIC:
<https://github.com/Wiznet/ioLibrary_Driver/tree/master/Ethernet>
The code is 99% directly portable, just the hardware comms part needs
to change.
The .chm file provides a complete manual to the functions provided.
You need the stuff that is in the root directory there, and then the W5500
drivers in the sub-directory.
These give complete API functions to actually open a socket, handle data
I/O using this etc. etc..
Then in the directory above:
<https://github.com/Wiznet/ioLibrary_Driver/tree/master/Application>
There are examples showing these drivers being used for a loopback
and multicast. |
ressas
Posted: Sat Aug 22, 2020 2:51 am |
Well alright.
I downloaded the Wiznet libraries from the place you said.
It would take me time to adapt to CCS c. But after a few minor fixes for Mplab IDE it was fixed. (Compiled without an error)
Later I found a code adapted for ARM.
https://www.carminenoviello.com/2015/08/28/adding-ethernet-connectivity-stm32-nucleo/
I watched a video showing the code working fine:
https://www.youtube.com/watch?v=zsLQm6SgL_c
void cs_sel() {
CS_SetLow(); //CS LOW
void cs_desel() {
CS_SetHigh(); //CS HIGH
uint8_t spi_readb(void) {
uint8_t rbuf;
rbuf = SPI1_ExchangeByte(0x00);
return rbuf;
void spi_writeb(uint8_t b) {
SPI1_ExchangeByte(b);
// Initialize the device
SYSTEM_Initialize();
SPI1_Open(0);
uint8_t retVal, sockStatus;
int16_t rcvLen;
uint8_t rcvBuf[20];
uint8_t bufSize[] = {2, 2, 2, 2};
wizchip_init(bufSize, bufSize);
//80-A5-89-62-0A-19
wiz_NetInfo netInfo = { .mac = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef}, // Mac address
.ip = {192, 168, 1, 50}, // IP address
.sn = {255, 255, 255, 0}, // Subnet mask
.gw = {192, 168, 2, 1}}; // Gateway address
wizchip_setnetinfo(&netInfo);
wizchip_getnetinfo(&netInfo);
// 0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef
//PRINT_NETINFO(netInfo);
reg_wizchip_cs_cbfunc (cs_sel, cs_desel);
reg_wizchip_spi_cbfunc(spi_readb, spi_writeb);
| Quote: |
void cs_sel() {
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_RESET); //CS LOW
void cs_desel() {
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_SET); //CS HIGH
uint8_t spi_rb(void) {
uint8_t rbuf;
HAL_SPI_Receive(&hspi2, &rbuf, 1, 0xFFFFFFFF);
return rbuf;
void spi_wb(uint8_t b) {
HAL_SPI_Transmit(&hspi2, &b, 1, 0xFFFFFFFF);
The part I show as "QUOTE" is the part given in the link. I guess I couldn't adapt that expression properly in my code.
SPR_writeByte // SPI_ExchangeByte // SPI_ExchangeBlock
I'm not sure which one of the expressions I should use.
Why am I asking for an edit of MPLAB IDE in CCS C block?
Because I rely on your deep knowledge.
And I don't like MPLAB's Blog page.
If you can help me with this part, I will share all the codes here in case the code works. And I was already sharing my other apps.
I'm waiting for your answer
and I'm tired |
