Expression must evaluate to a constant - Conditional Exp
MotoDan
PostPosted: Mon Jun 08, 2020 9:31 am     Reply with quote
Hello all,
Trying to fill a const array using a conditional expression and am getting an error 27 "Expression must evaluate to a constant". Have tried several things, but no joy.
The code below is a very simple test case and will not be used exactly as written.
I'm using the latest PCM v5.093. Have also tried older versions with same results.
TIA,
MotoDan
#include "16F18323.h"
int x, y;
   y = (x==5) ? 6 : 7;   // works
int const array1[][2] = {
   {1,2},
   {3,4},
   {5,(x==5) ? 6 : 7}   // error 27 here
gaugeguy
PostPosted: Mon Jun 08, 2020 9:40 am     Reply with quote
A constant array is an array of constants. x is a variable and is not a constant. y is a variable and may be assigned with another variable.
MotoDan
PostPosted: Mon Jun 08, 2020 9:52 am     Reply with quote
In this example, the intent is to fill one element of the array with a constant (either 6 or 7) based on the conditional expression of whether x=5 or not.
This type of conditional fill works with other C compilers. Just not sure why it won't work with CCS.
gaugeguy
PostPosted: Mon Jun 08, 2020 10:03 am     Reply with quote
The values in the const array are determined at compile time and stored in ROM. The value of variable x is not known at compile time.
MotoDan
PostPosted: Mon Jun 08, 2020 10:24 am     Reply with quote
To your point, I changed the code to fill a variable array rather than a constant array. The results are the same.
int x;
x=5;
int array1[][2] = {
   {1,2},
   {3,4},
PostPosted: Mon Jun 08, 2020 10:39 am     Reply with quote
The point is the the ?: operation is part of runtime code. Not something
that is evaluated at the compile time that can not therefore be used to
fill a variable at compile time.
MotoDan
PostPosted: Mon Jun 08, 2020 10:58 am     Reply with quote
I guess it's just the way that CCS compilers treat the ?: operation. I've verified my test code works with two other non-CCS 'C' compilers as well as the Arduino compiler.
MotoDan
PostPosted: Mon Jun 08, 2020 11:01 am     Reply with quote
Just received an email from CCS. They do not support what I am attempting to do.
Thanks for all the replies.
