Frozen01
getting individual bits out of a variable |
Posted: Wed May 27, 2020 10:09 am |
Here is what I need to do....
I read the serial stream (UART1)... I then want to pass to a function that I "bitbang" out to an oddball serial like device that does not fit the standard RS232 format.
Reading the port is not a problem, but I can't place my finger on how to extract out the bit pattern that I need to send. Input data is standard RS232 framed data.
Joined: 01 Jul 2010 Posts: 9522 Location: Greensville,Ontario
Posted: Wed May 27, 2020 10:28 am |
Quick comment..
CCS has a 'bit test' function you can use ! Check the manual for the correct syntax, but a simple 'loop' from 0 to 7, or 7 to 0, will 'extract' the bit from the byte, then you can do 'whatever' to send to the other device.
0 to 7 will get lsb to msb, 7 to 0 gets high bit first...
There may be an example in the code library, it's been used to send '1' or '0' to an LCD to 'show' the binary equal to a byte.
jay |
Frozen01
Posted: Wed May 27, 2020 11:40 am |
I got something working, ended up just using a for loop... |
bkamen
Posted: Sun May 31, 2020 10:37 am |
Right...
With a loop, you can either use the bit_tes() function and/or roll the bits using >> or << operators. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
